For my axis calibration, I find the slope with Vin values at 1 and -1 G positioning of the accelerometer relative to the axis I am interested in, using this formula (x is g and y is Vin values)
I then use this formula to find the tilt angle from my subsequent Vin readings
I find that I get a measurement of -90° at -1G, but an angle of 85° at +1G. Where does this error come from?
Edit: it is interesting to note how negative G direction has a much lower error percentage:
The calculations are as follow: calPG and calNG are the voltage read from the x axis at -90° and +90° Vin are the following V readings from the x axis, once slope was found G is gravity offset is optional, you can give it the value of angle measured at theoretical 0° (when the cube is placed so no acceleration is on x)
  • \$\begingroup\$ @user263983 the tilt angle is calculated without any movement, so only the earth gravity is tken into account during calibration and measurements \$\endgroup\$
    – JCSB
    Commented Apr 9, 2021 at 17:51
  • \$\begingroup\$ For accurate tilt anywhere near +-90 you will need to use the Y accelerometer as well as the X, if you have one. Y is on the steepest part of its slope there. \$\endgroup\$
    – tomnexus
    Commented Apr 9, 2021 at 18:40
A real accelerometer is going to have some nonlinearity and some offset error.
Because of how flat the sin function is near \$\pi/2\$, the difference between sin(85°) and sin(90°) is only 0.4%, so a measurement of 1.00V and -0.996V will represent that amount of error.
It's not unusual for inexpensive accelerometers to have a couple % of uncalibrated linearity error and some m\$g\$ of 0\$g\$ offset (that will also vary with temperature).
  • \$\begingroup\$ Thanks! but why is this error only in one direction?? sin(-90) vs sin(-85) are also very close, yet the measurement outputs -90° with a significantly lower error% \$\endgroup\$
    – JCSB
    Commented Apr 9, 2021 at 17:48
  • \$\begingroup\$ Presumably because it was calibrated out at +90°. \$\endgroup\$ Commented Apr 9, 2021 at 17:52
  • \$\begingroup\$ But I made sure I calibrated my slope from -1G and +1G Voltage inputs (the accelerometer is in a cube, so it was easy to measure V at 90 degree angles) \$\endgroup\$
    – JCSB
    Commented Apr 9, 2021 at 17:54
  • \$\begingroup\$ Is the voltage at -1G equal to - 1.00000 * the voltage at +1G? Is the axis misalignment accounted for? \$\endgroup\$ Commented Apr 9, 2021 at 18:21
    \$\begingroup\$ sin^-1(272/274) = 83° \$\endgroup\$ Commented Apr 9, 2021 at 18:55
If it is calibrated for null error at +-1 g why is there an error?
Possible Answer: calibration method error for gain and offset. Using only -1 g.
