I have previously only massaged Philips/NXP/Nexperia logic models from the HCT and LVC families, but took a stab at the LVT since you specifically requested the 74LVT04 in the question comments. It's a little more complicated than the other two, so I might have screwed something up in the process. With that disclaimer...below is the 74LVT04.lib
file which simulates a single gate when calling a single instance of 74LVT04
. If a 74LVT1G04 existed it would be more equivalent to that (see 74LVC1G04 to see what I'm talking about). The "nominal parameters" from nomps.lib
were used. Also note that the package parasitics from lvtpkps.s
are not present here.
* LVT Logic Family Single Buffered Inverter using nominal parameters
.SUBCKT 74LVT04 IN OUT VCC GND
R8 VCC 128 1K
R7 VCC 129 1K
M5 128 130 GND GND HVNMOS L=800E-9 W=4E-6 NRD= 6.625E-02 NRS= 6.625E-02 AD=7.2E-12 AS=7.2E-12
+ PD=11.6E-6 PS=11.6E-6
M4 129 131 GND GND HVNMOS L=800E-9 W=4E-6 NRD= 6.625E-02 NRS= 6.625E-02 AD=7.2E-12 AS=7.2E-12
X0 130 133 OUT VCC GND OUTBUFH
X1 131 IN 133 VCC GND INBUFBIG
.ENDS 74LVT04
.MODEL HVNMOS NMOS
+ LEVEL=3 TOX=15E-9 UO=460 VTO=0.7 NFS=1E11 NSUB=1E17
+ VMAX=153.4K XJ=0.2884E-6
+ RSH=6.0E3
+ DELTA=0.598 THETA=0.04 ETA=0.0649 KAPPA=20E-18
+ CJ=0.461E-3 MJ=0.325 CJSW=0.274E-9 MJSW=0.249 PB=0.76
+ CGDO=0.475E-9 CGSO=0.475E-9
+ JS=420E-9 IS=0
+ WD=0.129E-6 KF=3.180E-27 AF=1.160
.MODEL HVPMOS PMOS
+ LEVEL=3 TOX=15E-9 UO=180 VTO=-0.7 NFS=1E12 NSUB=7E16
+ VMAX=172K XJ=0.254E-6
+ RSH=4.0E3
+ DELTA=2 THETA=0.12 ETA=0.0805 KAPPA=20E-18
+ CJ=0.354E-3 MJ=0.328 CJSW=0.226E-9 MJSW=0.27 PB=0.65
+ CGDO=0.38E-9 CGSO=0.38E-9
+ JS=120E-9 IS=0
+ WD=0.11E-6 KF=4.180E-28 AF=1.160
.SUBCKT OUTBUFH 107 108 109 VCC GND
XQQ136 110 111 109 GND HV38STSBDETCNW
XQQ190 112 112 113 GND HV3STDBTC
XQQ191 114 112 115 GND HV3STDBTC
XQQ189 107 116 GND GND HV3STDBTC
XD135 VCC 110 GND HVDS2X45P2
XD140 115 VCC GND HVDS2X3
XD182 109 117 GND HVDS3X8
XD183 VCC 118 GND HVDS3X8
XD184 VCC 117 GND HVDS3X8
XD185 119 107 GND HVDS3X5
XD186 VCC 110 GND HVDS2X45P2
XD187 113 109 GND HVDS3X8
Q178 115 120 GND GND HV3DBTC
Q180 109 115 GND GND HV38SBDETCNW
Q179 118 121 107 GND HV3DBTC
M165 122 108 VCC VCC HVPMOS L=800E-9 W=10E-6 NRD= 2.650E-02 NRS= 2.650E-02 AD=18E-12 AS=18E-12 PD=23.6E-6
+ PS=23.6E-6
M164 123 122 VCC VCC HVPMOS L=800E-9 W=24E-6 NRD= 1.104E-02 NRS= 1.104E-02 AD=43.2E-12 AS=43.2E-12
+ PD=27.6E-6 PS=27.6E-6
M163 121 108 VCC VCC HVPMOS L=800E-9 W=35E-6 NRD= 7.571E-03 NRS= 7.571E-03 AD=63E-12 AS=63E-12 PD=73.6E-6
+ PS=73.6E-6
M166 112 108 123 VCC HVPMOS L=800E-9 W=24E-6 NRD= 1.104E-02 NRS= 1.104E-02 AD=43.2E-12 AS=43.2E-12
+ PD=51.6E-6 PS=51.6E-6
R162 108 111 500.0
R160 VCC 114 600.0
R161 VCC 123 8E3
M137 109 VCC 119 117 HVPMOS L=1E-6 W=20E-6 NRD= 1.325E-02 NRS= 1.325E-02 AD=3.6E-12 AS=3.6E-12 PD=7.6E-6
+ PS=7.6E-6
M162 107 108 118 118 HVPMOS L=800E-9 W=10E-6 NRD= 2.650E-02 NRS= 2.650E-02 AD=18E-12 AS=18E-12 PD=23.6E-6
+ PS=23.6E-6
M138 109 107 VCC 117 HVPMOS L=1E-6 W=650E-6 NRD= 4.077E-04 NRS= 4.077E-04 AD=1.17E-9 AS=1.17E-9 PD=103.6E-6
+ PS=103.6E-6
M136 119 VCC 107 117 HVPMOS L=1E-6 W=2E-6 NRD= 1.325E-01 NRS= 1.325E-01 AD=3.6E-12 AS=3.6E-12 PD=7.6E-6
+ PS=7.6E-6
X134 124 125 VCC GND OUTBUFH_1
X135 107 124 VCC GND OUTBUFH_2
M177 112 108 GND GND HVNMOS L=800E-9 W=10E-6 NRD= 2.650E-02 NRS= 2.650E-02 AD=3.6E-12 AS=3.6E-12
+ PD=7.6E-6 PS=7.6E-6
M176 115 108 GND GND HVNMOS L=800E-9 W=30E-6 NRD= 8.833E-03 NRS= 8.833E-03 AD=3.6E-12 AS=3.6E-12
M175 122 108 GND GND HVNMOS L=800E-9 W=10E-6 NRD= 2.650E-02 NRS= 2.650E-02 AD=18E-12 AS=18E-12
+ PD=23.6E-6 PS=23.6E-6
M167 107 108 GND GND HVNMOS L=800E-9 W=10E-6 NRD= 2.650E-02 NRS= 2.650E-02 AD=18E-12 AS=18E-12
M168 GND VCC 116 GND HVNMOS L=800E-9 W=4E-6 NRD= 6.625E-02 NRS= 6.625E-02 AD=7.2E-12 AS=7.2E-12
M169 116 125 108 GND HVNMOS L=800E-9 W=30E-6 NRD= 8.833E-03 NRS= 8.833E-03 AD=54E-12 AS=54E-12
+ PD=63.6E-6 PS=63.6E-6
M170 111 122 GND GND HVNMOS L=800E-9 W=20E-6 NRD= 1.325E-02 NRS= 1.325E-02 AD=36E-12 AS=36E-12
+ PD=43.6E-6 PS=43.6E-6
M173 121 108 GND GND HVNMOS L=800E-9 W=15E-6 NRD= 1.767E-02 NRS= 1.767E-02 AD=27E-12 AS=27E-12
+ PD=33.6E-6 PS=33.6E-6
M171 120 108 GND GND HVNMOS L=800E-9 W=2E-6 NRD= 1.325E-01 NRS= 1.325E-01 AD=3.6E-12 AS=3.6E-12
M172 108 125 120 GND HVNMOS L=800E-9 W=10E-6 NRD= 2.650E-02 NRS= 2.650E-02 AD=18E-12 AS=18E-12
M174 109 122 GND GND HVNMOS L=1E-6 W=30E-6 NRD= 8.833E-03 NRS= 8.833E-03 AD=54E-12 AS=54E-12
.ENDS OUTBUFH
.SUBCKT OUTBUFH_2 126 127 VCC GND
MQN7 127 126 GND GND HVNMOS L=8E-7 W=6E-06 NRD= 4.417E-02 NRS= 4.417E-02 AD=36E-12 AS=36E-12
MQP8 127 126 VCC VCC HVPMOS L=8E-7 W=4E-06 NRD= 6.625E-02 NRS= 6.625E-02 AD=36E-12 AS=36E-12 PD=43.6E-6
+ PS=43.6E-6
.ENDS OUTBUFH_2
.SUBCKT OUTBUFH_1 126 127 VCC GND
MQN7 127 126 GND GND HVNMOS L=8E-7 W=1E-05 NRD= 2.650E-02 NRS= 2.650E-02 AD=36E-12 AS=36E-12
MQP8 127 126 VCC VCC HVPMOS L=8E-7 W=1E-05 NRD= 2.650E-02 NRS= 2.650E-02 AD=36E-12 AS=36E-12 PD=43.6E-6
+ PS=43.6E-6
.ENDS OUTBUFH_1
.SUBCKT INBUFBIG 107 108 109 VCC GND
X7 108 109 VCC GND INBUFBIG_3
X19 108 107 VCC GND INBUFBIG_4
Q11 VCC 107 109 GND HV3DBTC
.ENDS INBUFBIG
.SUBCKT INBUFBIG_3 126 127 VCC GND
MQN7 127 126 GND GND HVNMOS L=8E-7 W=4E-05 NRD= 6.625E-03 NRS= 6.625E-03 AD=36E-12 AS=36E-12
+ PS=43.6E-6
.ENDS INBUFBIG_3
.SUBCKT INBUFBIG_4 126 127 VCC GND
MQN7 127 126 GND GND HVNMOS L=8E-7 W=2E-5 NRD= 1.325E-02 NRS= 1.325E-02 AD=36E-12 AS=36E-12
MQP8 127 126 VCC VCC HVPMOS L=8E-7 W=4E-05 NRD= 6.625E-03 NRS= 6.625E-03 AD=36E-12 AS=36E-12 PD=43.6E-6
+ PS=43.6E-6
.ENDS INBUFBIG_4
.SUBCKT HV38STSBDETCNW 1 2 3 4
QN 1 2 3 4 MTRN
DSCH 2 1 SCH
.MODEL MTRN NPN
+IS = 1.7195E-16 BF = 133.8 BR = 7.926E+00
+IKF = 0.06726 IKR = 0.01206 NF = 0.997
+NR = 0.9918 VAF = 30.0 VAR = 2.69
+RC = 1.477 RBM = 1.079 RB = 126
+IRB = 2.02E-5 RE = 0.294 CJE = 4.408E-13
+VJE = 0.91 MJE = 0.47 CJC = 2.709E-13
+VJC = 0.6 MJC = 0.28 XCJC = 1.000E+00
+FC = 8.750E-01 PTF = 1.000E+01 CJS = 2.585E-13
+VJS = 0.636 MJS = 0.36 TF = 11.0E-12
+TR = 8.573E-10 EG = 1.156
+ISE = 1.539E-16 ISC = 0.32E-14 XTB = 0.5266
+XTI = 3.687 XTF = 15 VTF = 1.5
+ITF = 0.26 NC = 2.131 NE = 1.603
.MODEL SCH D (IS = 110.8E-15 N = 1.0367
+ RS = 58 CJO = 4.95E-14 VJ = 0.7 M = 0.6
+ EG = 0.8633 XTI = 1.001)
.ENDS HV38STSBDETCNW
.SUBCKT HV3STDBTC 1 2 3 4
QN 1 2 3 4 MTRN
DSCH 2 1 SCH
.MODEL MTRN NPN IS= 7.72E-18 BF= 1.25E+02 VAF= 2.20E+01 IKF= 3.46E-03
+ BR= 4.00E+00 VAR= 4.00E+00 IKR= 1.02E-01 RB= 8.39E+02 IRB= 6.00E-07
+ RBM= 8.33E+00 RE= 1.06E+01 RC= 3.84E+01 XTB= 5.00E-01 EG= 1.20E+00
+ XTI= 3.00E+00 CJE= 1.74E-14 VJE= 9.10E-01 MJE= 4.70E-01 TF= 8.50E-12
+ XTF= 1.80E+01 VTF= 2.50E+00 ITF= 1.60E-02 PTF= 1.00E+01
+ CJC= 1.09E-14 VJC= 6.00E-01 MJC= 2.80E-01 TR= 4.11E-10
+ ISE=0.0 ISC=0.0 NF= 1.00E+00 NR= 1.00E+00 CJS= 5.20E-14
+ VJS= 6.36E-01 MJS= 3.60E-01
.MODEL SCH D (IS= 4.17E-14 RS= 1.98E+02 N= 1.04E+00 CJO= 9.90E-15 VJ= 7.00E-01
+ M= 6.00E-01 EG= 7.60E-01 XTI= 3.00E+00)
.ENDS HV3STDBTC
.SUBCKT HVDS2X45P2 1 2 3
DDIO 1 2 DIOM
DCAP 3 2 JCAPM
.MODEL DIOM D IS= 4.30E-13 RS= 1.97E+01 N= 1.04E+00 CJO= 1.02E-13
+ VJ= 7.00E-01 M= 6.00E-01 EG= 7.60E-01 XTI= 3.00E+00
.MODEL JCAPM D CJO= 1.77E-13 VJ= 6.36E-01 M= 3.60E-01
.ENDS HVDS2X45P2
.SUBCKT HVDS2X3 1 2 3
DDIO 1 2 DIOM
DCAP 3 2 JCAPM OFF
.MODEL DIOM D (IS= 2.73E-14 RS= 3.13E+02 N= 1.04E+00 CJO= 1.10E-14
+ VJ= 7.00E-01 M= 6.00E-01 EG= 7.60E-01 XTI= 3.00E+00)
.MODEL JCAPM D (CJO= 3.65E-14 VJ= 6.36E-01 M= 3.60E-01)
.ENDS HVDS2X3
.SUBCKT HVDS3X8 1 2 3
DDIO 1 2 DIOM
DCAP 3 2 JCAPM OFF
.MODEL DIOM D (IS= 1.13E-13 RS= 8.40E+01 N= 1.04E+00 CJO= 3.80E-14
.MODEL JCAPM D (CJO= 5.77E-14 VJ= 6.36E-01 M= 3.60E-01)
.ENDS HVDS3X8
.SUBCKT HVDS3X5 1 2 3
DDIO 1 2 DIOM
DCAP 3 2 JCAPM OFF
.MODEL DIOM D (IS= 7.03E-14 RS= 1.34E+02 N= 1.04E+00 CJO= 2.38E-14
.MODEL JCAPM D (CJO= 4.68E-14 VJ= 6.36E-01 M= 3.60E-01)
.ENDS HVDS3X5
.MODEL HV3DBTC NPN IS= 7.72E-18 BF= 1.25E+02 VAF= 2.20E+01 IKF= 3.46E-03
+ RBM= 8.33E+00 RE= 1.06E+01 RC= 1.00E+02 XTB= 5.00E-01 EG= 1.20E+00
+ CJC= 8.74E-15 VJC= 6.00E-01 MJC= 2.80E-01 TR= 3.32E-10
+ ISE=0.0 ISC=0.0 NF= 1.00E+00 NR= 1.00E+00 CJS= 3.89E-14
.MODEL HV38SBDETCNW NPN
+IS = 1.72E-16 BF = 133.8 BR = 7.926E+00
+IKF = 0.06726 IKR = 0.01206 NF = 0.9997
+RC = 3.686
+RBM = 1.079 RB = 126 IRB = 2.02E-5
+RE = 2.94E-01 CJE = 4.408E-13
+VJE = 0.91 MJE = 0.47 CJC = 2.921E-13
+ITF = 0.26 nc = 2.131 ne = 1.603
You can also create a full chip 74LVT04D (SO14) by creating another subcircuit which calls 6 instances of the single gate subcircuit. Below is an example of this (untested). I didn't attempt it, but this is where you should manually add the package parasitics if you need that extra accuracy.
.SUBCKT 74LVT04D IN1 OUT1 IN2 OUT2 IN3 OUT3 GND OUT4 IN4 OUT5 IN5 OUT6 IN6 VCC
X1 IN1 OUT1 VCC GND 74LVT04
X2 IN2 OUT2 VCC GND 74LVT04
X3 IN3 OUT3 VCC GND 74LVT04
X4 IN4 OUT4 VCC GND 74LVT04
X5 IN5 OUT5 VCC GND 74LVT04
X6 IN6 OUT6 VCC GND 74LVT04
.ENDS 74LVT04D
I don't use PSpice because all the cool kidz (yes, with a Z
) use LTspice. Therefore, below are some screenshots from LTspice which I took...while wearing my shades of course. I also included the code for the LTspice symbol (74LVT04.asy
file) I used.
Version 4
SymbolType CELL
LINE Normal -32 -32 32 0
LINE Normal -32 32 32 0
LINE Normal -32 -32 -32 32
LINE Normal 0 -32 0 -16
LINE Normal 0 32 0 16
CIRCLE Normal 48 8 32 -8
WINDOW 0 24 -32 Left 2
WINDOW 3 24 32 Left 2
SYMATTR Value 74LVT04
SYMATTR Prefix X
SYMATTR Description LVT Family Inverting Buffer
SYMATTR ModelFile 74LVT04.lib
PIN -32 0 NONE 0
PINATTR PinName IN
PINATTR SpiceOrder 1
PIN 48 0 NONE 0
PINATTR PinName OUT
PINATTR SpiceOrder 2
PIN 0 -32 NONE 0
PINATTR PinName VCC
PINATTR SpiceOrder 3
PIN 0 32 NONE 0
PINATTR PinName GND
PINATTR SpiceOrder 4
.subckt
or.model
. The.model
you see there is not one recognizable by SPICE, but it might be by some exotic flavour of it (i.e. custom made). \$\endgroup\$
