MD\F 0 1
00 0 1
01 0 1
11 1 1
10 0 0
this is a karnaugh map.
Now , I take in horizontal 1 1 . As a result I have M*D. The F is 0 if we see that it means NOT F and we have 1 so F it remains F. The F I can erase it ,is that right? I have the equation for horizontal
M*D + ..
After this,I want after + of that equation to fill it with the vertically the 1 1 I have. As we see vertically I have 1.As a result we have F. that means our equation goes like this
M*D + F
After this I feel I don't make it right.I look at MD in the first row are
     M D      and we have F
     0 0                  1
so it is not M NOT D.Lets write it M' D'
for the second row 01 of the MD
it is 01 and in the vertically we have 1. NOT M *D ,lets write this M'*D
that comes to this the equation is M*D + F(M'D' * M'*D). I simplify the equation so it is
M*D +F*M'
Is right the equation?
Yes $$MD+F\mathop{\overline{M}}$$ is the right answer.
The upper vertical group 11 is for M=0 and F=1. You do not consider D since it is the variable that is changing state inside the group.
Check this: https://electronics.stackexchange.com/a/555144/254042
You do not need to rethink the Boolean simplification properties when using K-maps. You apply rules and get the simplified expression otherwise it would be useless.
