I have having a bit of difficulty calculating rpm of a motor using feedback from an encoder. The encoder datasheet is attached here: Encoder datasheet.
The encoder has two channels at 1000 PPR, so 4000 PPR that I can count with my FPGA, as I am counting both the rising and falling edges. The max motor speed is 4500 rpm.
I have synchronized these pulse edges with the FPGA 100MHZ clock and I generate a pulse on each rising and falling edge that lasts for one 100 MHz clock cycle. I then have a counter that increments by one on the falling edge of the 100 MHz clock if an edge pulse has been generated. This counter value is clocked into a register every 100 ms which is the count value from the encoder. I then display this count value on a seven segment display to test it.
I have inputted a 20 kHz square wave into the FPGA to simulate one channel of the encoder and the display reads a count value of 4000 on the display. So the hardware on the FPGA end is working perfect, as the counts per 100 ms from 20 kHz is 4000.
I am unsure how I can scale this count value from the encoder mathematically into an RPM value that I can display? At 4000 rpm, the encoder inputs will be 66.6 kHz each. So for around 4000 rpm, the count value per 100 ms will be 26640. I tried to use the following algorithm:
$$ RPM = \frac {(CountValue per 100 ms) (600)} {EncoderPPR} , $$
But to remove the division by 4000 and to shift right to divide by 4095:
$$ RPM = \frac {(CountValue per 100 ms) (600\frac{4095}{EncoderPPR}) } {4095} , $$
So this leaves:
$$ RPM = \frac {(CountValue per 100 ms) (614.25)} {4095} , $$
With the encoder my display is not displaying 4000 rpm so would like to know if anyone can spot a mistake in my calculations.
EDIT
So I actually changed the shift value from 12 (4095) to 14 (16383) and the rpm is not being displayed correctly as far as I know. I have a digital tachometer to measure the speed of the motor shaft as they fluctuate within 2 rpm of each other. I am guessing the extra to shift bits was because 614.25 has two places after the decimal point?
