I want to use a load switch for protecting my PCB.
I also want to watch/measure the current drawn by my board.
How can I sense/measure the current drawn by my board, using a load switch like the Microchip UCS3205T-E/Q8A?
I can't find articles about sensing/measuring the load current.
Load switch TPS272C45 by Texas Instruments outputs the current drawn by the load.
https://www.ti.com/lit/ds/symlink/tps272c45.pdf?ts=1618175801421
SNS is an analog output pin that outputs the analog output current drawn by the load.
Connect a resistor between SNS and GND.
This a selection filter at Texas Instruments in case you want to browse other load switches:
https://www.ti.com/power-management/power-switches/high-side-switches/products.html
