I am working on a project where stm32 HID device is connected to a PC using USB cable. There is no need for unplugging on the product side, so can I replace a usb connector with JST one or directly solder it on board? Does the metal part of micro usb play a role in data transfer?
\$\begingroup\$ This has been done in at least one product I'm using, with the connector available to the customer. I own a bigger version of that device and it works pretty nicely. \$\endgroup\$– jaskijApr 13, 2021 at 10:53
\$\begingroup\$ The metal part connects the shield which helps with EMC but does not itself carry data. if you need the shield on your device just use another connector pin. \$\endgroup\$– JasenApr 15, 2021 at 20:12
1 Answer
A lot of USB devices such as keyboards or mice have a captive cable which either has a custom connector is directly soldered to board.
The Micro USB connector itself plays no role in the data transfer.
