6
I've got a GPS circuit where the antenna is connected directly to the GPS receiver via a coplanar waveguide designed for an impedance of 50ohms. Unfortunately, I neglected to add the bias-t circuit that is used to provide power to the GPS antenna. Luckily, I was able to remedy this problem on the prototype by breaking the transmission line, soldering a 22pF cap across the gap and connecting the antenna side directly to a nearby 3.8V trace on the PCB. The GPS was able to get a fix in about 20s and happily tracked 9 satellites.
I now need to incorporate the capacitor and inductor of the bias-t into the circuit (Reference Design page 150) and I was wondering what considerations I need to make in order to ensure that the transmission line remains at 50ohms?
The capacitor and inductor values are chosen so as not to disturb the line impedance. In practice, we would aim for the capacitor in this case to be as near a short circuit (0 Ohm impedance) and the inductor as near an open circuit (infinite impedance) at the frequency of interest (~1575MHz or 1227MHz for GPS). Just use RF components (I would recommend a low ESR chip-scale ceramic cap and chip-scale wound inductor) and as a rule of thumb I'd be looking for a cap impedance <1 Ohm and inductor impedance >20x your line impedance.
