I try to run a simple RLC circuit under ngspice in batch mode and the netlist is written as follows:
Series RLC Circuit
V1 1 0 ac 100 0
R1 1 2 200
L1 2 3 0.125
C1 3 0 1U
.ac LIN 10 10 100
print ac v(1) i(V1)
.END
I run this netlist by giving the following command:
ngspice -b RLC.cir
And i get the following Error Massage which I don't understand :-(!
Circuit: series rlc circuit
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
Warning: v1: has no value, DC 0 assumed
No. of Data Rows : 10
Error(parse.c--checkvalid): data: no such vector.
Note: No ".plot", ".print", or ".fourier" lines; no simulations run
  • \$\begingroup\$ so do you need to add a '.' before your print line? \$\endgroup\$ – Analog Arsonist Jan 24 '13 at 17:26
First error is because your ac is NOT AC, it's not seeing it and defaulting to a current probe.
Print line must be .print AC and Maybe .PRINT AC
I notice that in your print statement case is different on on v vs. V.
| improve this answer | |
