I am building a system with multiple sensors and I want to sample the different sensors at different rates. For the sake of an example, I am using two MAX30102EFD-T sensors. One of the sensors I want to run at 50Hz and the other I want to sample at 1000 Hz. I have the ability to configure this sampling rate (samples per second) on the sensor and when each sensor has a new sample (supposedly at these frequencies), in the interrupt I can record this sensor value (and optionally record a timestamp like the number of milliseconds since boot.
As an example:
TIMESTAMP SENSOR VALUE
0         1      1.2
0         2      0.1
1         1      1.3
2         1      1.4
3         1      1.5
The issue is that storing timestamps along with the time series from both sensors can add significantly to the output file size. If the sampling rate of these sensors is reliable enough, I could just record the initial timestamp and the sampling rate and assume uniform sampling, but I'm hesitant to trust these types of sensors to have that uniform and accurate of a sampling rate. Is that distrust warranted in general?
I'm curious if anyone has any experience with such a thing and was interested to see if there was a robust approach short of storing timestamps for each sensor alongside the data.
  • \$\begingroup\$ Is there downstream processing of this data? In addition to log space, the challenge with time-stamping is that you need to include the system timer. There are certainly advantages with a good system timestamp, but there are many pitfalls in implementing it correctly. As a small aside, I would refer to what you have now as "sample index" not timestamp. \$\endgroup\$
    – crasic
    Apr 14, 2021 at 15:16
  • \$\begingroup\$ Using some kind of check to ensure you aren't missing entire samples is definitely a good idea, but the expected sample jitter of these devices will likely be pretty good. \$\endgroup\$
    – crasic
    Apr 14, 2021 at 15:19
  • \$\begingroup\$ @crasic Yes the resulting output will need to be processed assuming absolute timestamps. Also yes, sorry about the "timestamp" column, in our situation we will have actually timestamps there, but wanted to simplify for an example \$\endgroup\$
    – Suever
    Apr 14, 2021 at 15:20
  • \$\begingroup\$ @crasic So would you do this check in the interrupt routine and add in filler values as needed if there is too big of a gap? \$\endgroup\$
    – Suever
    Apr 14, 2021 at 15:21
    \$\begingroup\$ @Suever Okay. So it's all within a board. That's good. This said, you should definitely observe the rule I mentioned at the outset. PID control, which you aren't doing but which is an example case to make a point, is like trying to poke a long bamboo pole into a birdhouse hole. If the pole is long, it's hard. If the length of the pole keeps varying, it's even harder. If both are happening? May as well just give up. So I keep the length of the pole exactly the same and rigorously unvarying. And I try and keep that pole as short as possible, too. (ADC to Control Output.) \$\endgroup\$
    – jonk
    Apr 14, 2021 at 20:44
I spent 30 seconds looking at the datasheet (Ctrl-F "Frequency") and, well, it doesn't have an onboard crystal oscillator, so the internal clock is pretty inaccurate, and it will drift.
Therefore, using your microcontroller to create timestamps seems reasonable. So there are two isuses: the absolute accuracy of the timestamps given by your microcontroller, and the synchronization between both sensors. If all you care about is knowing when a sample from the first sensor was acquired relative to the sample from the other sensor, so your 50 Hz and your 1000 Hz line up, then the accuracy or drift of the timestamps from the microcontroller clock isn't that important, because if it drifts, then the timestamps for both sensors will be affected equally, and the order of samples will still be the same.
If you want to know the sample was acquired on monday at 12:01:00 to the microsecond, then it's another problem.
Not really, you can compress it like time series databases do : by storing deltas. For example if you expect one sample every millisecond, and your timestamps are based on a 10MHz clock, then you store the first timestamp as a 32 bit value, then you store the difference between timestamps. And since that difference will always be close to 10000 (10MHz/1kHz) you can store deltas of deltas. This should get you down to 1 byte per timestamp.
It would probably be simpler to not use the free-running mode in the sensors and just run a 1ms timer in your micro, so you know the 1kHz sensor is synrhronized to the micro's internal clock, which presumably comes from an accurate crystal. Then every 20 samples, request a sample from the 50Hz sensor. Then you can be sure both sensors sampling times line up.
  • \$\begingroup\$ Thank you for the answer @bobflux! Great tips on timestamps in those files, I'll do some investigation to see about implementing something such as that. Also thanks for the suggestion to use a centralized timer for the sampling instead of relying on the different sensors which will (as we add more sensors) inevitably have different accuracies and drift. \$\endgroup\$
    – Suever
    Apr 15, 2021 at 19:10
