I need to power a miniature LED light show that will draw a few hundred mA, or possibly more, and requires less than 5 Vin, and a microcontroller board that wants 7-21 Vin.
I was thinking the easiest solution would be to use 3 AA alkaline cells in series, to provide 4.5 V, which is fine for the light show, and then 3 cells in series with that to provide 9 Volts, which is good for the microcontroller board, which will only draw 20-30 mA. Then I wouldn't need to worry about a voltage regulator, and wouldn't have to do worry about heat dissipation inside the electronics enclosure, I've heard that those Voltage regulators dissipate heat under heavier loads.
So, the two systems will have a common ground connector, and two different V+ connectors.
But many places I've heard that it's bad to combine more depleted batteries with less depleted batteries, and since the first three cells will have more current draw than the next three, that will eventually happen. But I don't understand it completely, because surely not all batteries will be exactly equal in terms of capacity, so sooner or later one battery might get discharged while the others still have charge, even for conventional setups?
So will the above setup work, and is it OK practice? Or am I being paranoid regarding the voltage regulator solution? The thing is that I'm not completely sure about the power draw of the light show, because it will also depend on the contents of the show itself. I only know it's within acceptable limits for alkaline AA cells.
I see a similar question has been asked, but it focused on rechargeable batteries, and the answers focused on problems related to charging, while my question is specific to alkaline cells that are not going to be recharged.
