I'm curious regarding some matters in my experiment session of Efficient Lighting System. There are 4 types of lamps which we measure the data to fill-in the table as in the picture. Correct me if my hypothesis is wrong.
- The brighter the lamp, the higher the magnitude of luxes.
- Does the higher the neutral current, the more it consumes energy?
- CFL does consume more current as it produces brightest light which could be prove based on the lux value in the picture.
- Electronic ballast is one type of lamp that can be categorised as energy efficiency because it uses less neutral current but produces higher brightness.
But what indicates the value of real power, reactive power, apparent power and power factor ? What are those powers relatable with this types of lamp? If you have any points to add, please do so.
