6
I am examining the st-micro rtd circuit for the STM32373C-EVAL kit. What does this circuit do?
Can I use it to support both pt100 and pt1000 rtd elements? The circled area is the point of confusion.
op-amp-circuit
http://imgur.com/QsWV0hI
This circuit is a precision constant current source for the PT100 (R30 in the schematic). This is a Howland current source (principles of operation here).
If you use as is it with PT1000, it would work in general. You might see more self-heating. The output would rail at a lower temperature.
The current is inverse-proportional to R3x**. You can reduce the current by increasing R3x.
** The designator is obscured by the black circle. The resistor is directly above JP18.
