I've wrote a verilog code for Multiplier (8bit). I'm not getting the right result. Kindly tell me where i went wrong.
module Multiplier (x,y,z);
input  [7:0]x,y;
output [15:0] z;
assign z=x*y;
endmodule
It got compiled without any errors. But when simulating, it gives me wrong results. It gives wrong results only when the MSB of the numbers is 1 (i.e when negative numbers are considered). Here is the picture of the simulation. enter image description here
Kindly help me with how to rectify this problem. Also, I have another question to ask. While writing a code in modelsim, I observed some line numbers marked in red, Can anyone tell what they mean?
There is nothing wrong in it. You are multiplying two unsigned numbers in your Verilog code. So you will get an unsigned result. The valuesx, y and z are by default unsigned unless you explicitly specify it as signed.
For example, this is what actually happened in the first stimulus:
$$181_{10} \times 223_{10} = 40363_{10}$$
These values are interpreted as unsigned by the simulator for multiplication. The result is correct as well.
But for display purpose, you probably set your simulator to represent the waveforms in signed radix instead of unsigned radix.
So, MSB is now considered as sign bit, and if MSB = '1', the number is considered to be negative and the magnitude is in two's complement form. And hence the simulator displayed:
181 as 181-256 = -73,
223 as 223-256 = -33, and
40363 as 40363 -65536 = -25173
  • \$\begingroup\$ can you also tell me why some line numbers are marked red in modelsim (i.e., the second image)? \$\endgroup\$ – Kuchi Yashwanth Apr 17 at 4:25
  • \$\begingroup\$ I am not sure about that. \$\endgroup\$ – Mitu Raj Apr 17 at 4:27
  • \$\begingroup\$ Maybe showing which statement is currently executed by the simulator. \$\endgroup\$ – Mitu Raj Apr 17 at 4:33
