I am a mechanical engineer and I am developing a enclosure for one of the electrical setup. It has usb, ethernet and power supply ports. I am unaware how IP rated USB or any other USB port make sure that there is no water ingress inside the port. Any suggestion would be great on how this can be achieved.
  • \$\begingroup\$ I'm pretty sure you have to not use a standard USB connector. Look for IP66+ rated USB connectors. \$\endgroup\$ – Hearth Apr 19 at 6:38
  • \$\begingroup\$ Thanks for your reply @Hearth. Appreciate it. Is there any way we could use the standard USB connector for these enclosures (IP 66 rated). Or looking out for IP rated connectors are the best options. \$\endgroup\$ – Rohan Apr 19 at 7:37
  • \$\begingroup\$ The IP66 probably relates to the housing internal with the connector installed. You'd still have ambient conditions at the connection point. This can be overcome with a removable cover. You could also make the mated connector IP66. O rings are probably a good starting point. \$\endgroup\$ – Russell McMahon Apr 19 at 8:20
  • \$\begingroup\$ A look at the images on @Enrico's links makes it clear how the rating is achieved/ \$\endgroup\$ – Russell McMahon Apr 19 at 8:21
  • \$\begingroup\$ Thank you @RussellMcMahon, so the interior part of the USB is not waterproof? and only the housing is Rated. \$\endgroup\$ – Rohan Apr 19 at 8:42
Ordinary USB and Ethernet connectors are not IP66 rated.
There are many IP67 and IP68 USB and Ethernet connectors around but I couldn't find one IP66 rated.
Reliable manufacturers of IP66/IP67/IP68 rated USB and Etehernet connectors are, among many others: Molex, TE, Bulgin, Amphenol
Molex: https://www.molex.com/molex/products/family/industrial_usb_type_a_and_b_plugs_and_receptacles
TE: https://www.te.com/global-en/products/connectors/intersection/industrial-usb-connectors.html?tab=pgp-story
Bulgin: https://www.bulgin.com/products/pub/media/bulgin/data/Standard_ethernet.pdf
Amphenol: http://amphenolltw.com/flipbook/AmphenolLTW/ALTW%20catalogue.pdf
You can buy them at your local distributor or at Digikey.com or Mouser.com
  • \$\begingroup\$ Thnaks alot Enrico. Appreciate your time, but any suggestion on how they achieve it, so that if possible, could give it a try. \$\endgroup\$ – Rohan Apr 19 at 7:32
