This GPS module I have broke (just gets hot and won't work) so I took it apart and am amazed to see all of this circuitry under the ceramic antenna but only two connections (gnd and signal). When tested there is ~3v between the signal and ground wires. So how does it work to send power over the wire and then also get signal back along the same wire ?
3\$\begingroup\$ For further confusion I invite you to look up atenna/repeater systems that have no cables in or out but have a log of circuitry in them. You can send Power and Signal over the RF channel, filter out some power to run your circuits and use that to process the signal or send it on. Same basic idea, power and data can come from the same source but be treated it differently. \$\endgroup\$– TafTApr 20, 2021 at 11:00
Let's take a look at an annotated version:
There are two main paths to take a look at here - the RF path and the DC path.
The RF path starts at the patch antenna feed (center of the board) and spirals out and around through two amplifiers and a bandpass filter. With RF systems, you want to amplify the received signal as soon as possible before you run it through a long cable, and that's exactly what's going on here, except the cable is quite short. You also want to limit the bandwidth to limit the effects of out-of-band interference, which can affect the signal of interest through nonlinearities in the amplifiers. It looks like the antenna module is designed for use as a separate integrated module, and the mfr decided to glue it on to the back of the GPS module instead of connecting it with a long cable. Anyway, the RF signal from the antenna is routed through a low noise amplifier (LNA), then a bandpass filter, then a second amplifier to provide a bit more gain before being sent down the (potentially long) cable to the receiver. The RF components are interconnected with DC blocking capacitors so that they can be properly biased.
The DC path starts at the coax cable and leads to the amplifiers. DC power is separated from RF (~1.5 GHz for GPS) using a series inductor followed by a shunt capacitor. These components essentially form an LC lowpass filter that allows DC to pass, but blocks RF. Coupled with a DC blocking capacitor on the RF path, this circuit is called a bias tee, a three-port circuit which combines/separates DC (bias) and RF. Then, the extracted DC is used to power (bias) the amplifiers through bias resistors. Interestingly, it looks like there is no voltage regulator, but I do see what appears to be a spark gap on the board to allow any high voltage that could be applied to the cable to jump to ground.
On the GPS module, there will be a similar bias tee circuit to inject DC power into the coax cable.
The reason that power is injected back up the coax cable is for cost and convenience. The coax cable is necessary for RF, if it can be used for DC power as well then no additional wires are required, saving both parts cost and installation cost/complexity. In this case, it's a bit silly as the cable is only about 1 inch long; usually you see this technique used when there is a decently long cable separating the GPS module from the antenna.
\$\begingroup\$ WOW. you knocked that one out the park ! thanks you so much. \$\endgroup\$– tavisApr 23, 2021 at 23:13
All that circuitry operates from DC power sent along the signal cable from a DC power supply. The received GPS signal is amplified by the circuitry and sent along the signal cable as a radio frequency (RF) signal to the connected GPS equipment.
The DC power and RF signals are combined and separated by circuits known as bias tees. An inductor (coil) in the bias tee allows DC power to pass through whilst blocking RF signals. A capacitor blocks DC whilst allowing RF through. A bias tee built in to the GPS aerial feeds DC power from the signal cable to the supply rails of the circuitry and connects the received RF signal to the cable. At the equipment end another bias tee allows DC power to be fed to the cable and connects the RF signal to the GPS receiver. This bias tee can either be built into the equipment or provided as a separate (small) box.
This type of circuitry is often used with antennas and other components that cannot support multi-conductor cables. The main approach is to send DC power down the cable and the AC signal up the cable. The two types of signals are separated by using a capacitor (high DC resistance and low AC impedance) to couple the AC signal to the cable while blocking the DC power and an inductor (low DC resistance and high AC impedance) to couple the DC power to the circuitry while blocking the AC signal.
1\$\begingroup\$ in this example the capacitor is marked "C1" and the inductor is the square zig-zag trace, (it may actually be a tuned transmission line, but it serves the same purpose) \$\endgroup\$– JasenApr 20, 2021 at 7:42
\$\begingroup\$ If you still have problems understanding this, an experiment: plug a kill-a-watt into the wall, and then run an extension cord to another room, then your friend needs to plug something in the extension cord, and you can see if something is plugged in the initial room, with only 2 wires (plus 1 unused safety ground) \$\endgroup\$– FerrybigApr 20, 2021 at 10:02
\$\begingroup\$ @Ferrybig: An even better example would be POTS (Plain Old Telephone Service) line, which combines bidirectional audio signaling with power and off-hook signaling, over a single pair of wires that's floating with respect to ground (though usually with both wires biased to a negative voltage with respect to ground, to minimize corrosion). \$\endgroup\$– supercatApr 21, 2021 at 17:51
In general, you can transmit several signals along the same cable if they occupy different frequency bands. You can always filter out the singal of interest with the appropriate bandpass filter.
That's how powerline network adapters send Ethernet signals alongside the 50 Hz / 60 Hz mains power, or ADSL modems transmit data on the same wire the analog phones use for voice at the same time.
\$\begingroup\$ Interestingly, it's even possible to use an amplifier to amplify both a modulated signal and its demodulated counterpart. I recall a 3-transistor radio that did this. One of the amplifying transistors received both an RF signal from the antenna and a demodulated signal from the detector. LC circuits were used to separate out the RF and audio-frequency components from the amplifier output which were fed to separate amplifying transistors. The output of the second-stage RF transistor was demodulated and then fed back through the first amplifier stage which amplified the resulting audio. \$\endgroup\$– supercatApr 21, 2021 at 17:48
