I have read this equation from Savant's book that is used to calculate the capacitor for a demodulator:
I've tried to calculate my circuit with this equation, but it didn't work. Then I tried to recalculate this example from the book, but I don't know what is 'w' here in the example:
A 15MHz radio frequency carrier is modulated with a 5kHz signal with a modulation index (m) of 0.5. If the load resistance is 5 kOhms, what capacitor value must be added in parallel to the load to filter the radio frequency signal?
response: 0.013 uF
Can you please teach me how to obtain w so I can calculate C? I tried with 15MHz, and 5kHz, but I don't get the same answer.
\$\omega\$ is the angular frequency.
\$ \omega = 2\pi f \$
This makes your equation: \$ C = \frac {1}{2\pi f R_Lm}\$
For your example:
\$ C = \frac {1}{2\pi (5000) (5000) (0.5)} = 0.01273239µF \approx 0.013µF\$
\$f\$ is the frequency of the modulation signal (5kHz,) not the carrier (15MHz.)
  • \$\begingroup\$ I lot of thanks, you're so kind, thank you for your answer \$\endgroup\$
    – Aethox
    Apr 20, 2021 at 15:41
