I tried to decrease value of Rg resistor on the gate of the MOSFET (the one on the right) but then the MOSFET does not open enough and i get low currents trough it, i have this setup on breadboard and results are very close to simulation, when i have voltage at 10V and current fully closed i read 15-20mA on the DMM.
I use IRF630 for MOSFETS and the circuit is powered off laptop charger 19V.
Thanks.
Edit: There is also error in regulation, preventing the mosfet to close fully as there is 3.2V at gate when the voltage is closed, i guess that is the reason it does not close.
Link to simulation: Falstad Simulation
