I have another question about PCB layout. I'm designing using this guide:
I don't find nothing about problems between power planes and USB traces. Will it be problems if I create a power plane under the component and USB traces? Thank you so much!
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have another question about PCB layout. I'm designing using this guide:
USB 2.0 interfaces up to 12 Mbit/s (full speed) won't have problems if you put a ground plane beneath or not, provided you draw the PCB traces D+ and D- of the same length and short: the shorter the better.
In 2016 I designed a PCB with NXP LPC2388 microcontroller which has a USB 2.0 interface running at 12 Mbit/s.
The length of the PCB traces were 18 mm.
Both host (USB flash drive) and device (removable hard disk) interfaces worked perfectly.
