I have a part i imported from manufactuerers part list and has the following layout:
This is the layout pattern in it's datasheet:
I had set DRC rules to have a min via hole size of 0.3mm and this is why this error pops up. Should i simply ignore this error? Is there a way such that i still get all other DRC errors but this one doesn't show up?
Or would you remove the min via size rule altogether?
The manufacturers I am considering for this PCB have the following on their website:
