Picture of resistors
As the picture shows, is this a potentiometer, or is it supposed to be two resistors?
The picture shows two potentiometers, each of value 100k. The wiper of each potentiometer is connected to a fixed resistor, one of 100k and one of 1M. Each fixed resistor is connected to what looks like a thermistor (the circled things marked 10k.)
Figure 1. Equivalent circuits.
  • R1 allows selection of a bias voltage between 0 and -12 V.
  • R2 limits the current from the bias to the next stage of the circuit.
  • Note that your coarse pot wiper resistor is 100 kΩ and the fine is 1 MΩ. If they both feed into the same circuit the fine pot adjustment will be ten times more sensitive than the coarse pot because the 1 MΩ resistor reduces its effect to one tenth that of the coarse pot.
