I understand having test points on a production board, but what would be the point of selectively soldering some of them? It doesn't modify any resistance, right?
I assume that the large numbers of potentiometers ("Voltage Regulators") are for ensuring precise final voltages more cheaply than precision resistors? Curious if I'm wrong though.
Taken from the faceplate LCD driver for a car stereo system.
Image of multiple potentiometers and soldered test points on a production board
  • \$\begingroup\$ Might just be a mistake in the solder stencil or something, I wouldn't put too much thought into it. Probably cost more to fix than it was worth. \$\endgroup\$
    – Ron Beyer
    Apr 23 at 3:58
  • \$\begingroup\$ The factory probably has an automated test jig to adjust the settings. They probably found the whole solution was cheaper than the other alternatives. Personally I would’ve done it electronically so the adjustments are stored in memory. \$\endgroup\$
    – Kartman
    Apr 23 at 4:01
  • \$\begingroup\$ Maybe someone soldered a wire to that testpad at some point for debug or whatever. The solder cannot really affect the circuit in any meaningful way. Solder on a testpad will typically make connections with the test fixture less reliable. FYI. \$\endgroup\$
    – mkeith
    Apr 23 at 4:07
It looks intentional, either from the solder paste stencil or by hand at some point afterward. I doubt we will be able to figure out why it was done.
Adjustment can compensate for variations in several different components at once, and sometimes do a better job of it, so I suspect if they could have just used 1% or 0.5% resistors and gotten acceptable performance then they would have.
Modern designs often use EEPROM storage to save calibration settings, but usually there is a compromise involved (for example you might lose 20-30% of dynamic range to ensure that all units can be trimmed in despite production spread) and there is the possibility of memory corruption "bricking" the device.
Trimmers can drift, but if the circuit is well-designed and the adjustment range is no more than necessary that is not usually an issue, assuming screwdrivers are not involved.
Yes, there is no point of soldering these test-points. As the name suggests it serves the purpose of diagnosing the P.C.B. Also these test points have a routing present with the other sections of the circuit so soldering doesn't form any electrical connection.
The Soldermask between the adjacent pad and the test point is very small. Small enough that excess solder paste or a slight defect or lift of the stencil would cause solder to be deposited there during normal process from time to time.
This specific item is of little consequence but some strict producers may see this as a process quality indicator
For example, it could indicate the stencil is worn.
But this is pure speculation. There could easily be another , just as inconsequential reason.
