The following circuit diagrams are taken out of Niel Albaugh's The Instrumentation Amplifier Handbook
I understand how the RC (tolerances) mismatches in Figure 4-16 (left circuit) cause the two time constants to not perfectly match and result in differential signal, and the error gets amplified to the output. OK. Then the author suggested a fix to the circuit by adding C3, and that the circuit on the right (Figure 4-20) is an
(page. 52) ... an improved method of instrumentation amplifier input noise and RFI filtering ... even though the R1C1 and R2C2 mismatch remain the same, there is less common mode voltage to differential voltage conversion with this filter.
I don't get this. If the frequency is low (no RFI), C3 is no more than an open circuit, and the circuit on the right is identical to that on the left. If frequency is high enough (RFI), C3 will appear to be a short circuit - there won't be any voltage potential across the two inputs. I don't see how C3 filters RFI other than zeroing out the inputs whenever the signal is influenced by a high frequency RFI.
Would someone explain how Figure 4-20 improved noise and RFI filtering? (I hope this is not a typo or misprint from an aged old text)
