I've seen the assumption of gain-bandwidth product being constant for some amplifiers. More specifically for a compensated op-amp.
Is there any mathematical proof to establish why the product is constant?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI've seen the assumption of gain-bandwidth product being constant for some amplifiers. More specifically for a compensated op-amp.
The GBW product of an op-amp is set by internal resistances or current sources, and an internal capacitor. These are all made on silicon, and will be quite variable. The one datasheet that I checked lists the GBW product as "typical", without even giving a minimum and maximum.
Bottom line: if you're depending on the GBW product to be constant, you probably want to revisit the decisions you made designing that circuit.
As I understand your question, you are not asking about constancy (repeatability) from one device to another, but about the constant 6 dB per octave slope of the gain-bandwidth function. If so, then ...
Yes.
It is the math of an integrator, a single-pole, R-C lowpass filter, which is derived from the charge equation of a capacitor.
https://en.wikipedia.org/wiki/Capacitor#Parallel-plate_capacitor
https://en.wikipedia.org/wiki/Capacitor#AC_circuits
These sections spell out the math that show the impedance of a capacitor to be inversely proportional to the frequency of the signal going through it. If you plot the ratios of the impedance at various frequencies against the ratios of those frequencies, the log-log plot is a straight line.
