What is this part called? It's the plastic part of a row of pin headers, by itself.
I got a strip of these with a kit once but I don't know how to find more of them.
They're useful because stacking headers are often a bit too long.
    \$\begingroup\$ That would have been a really impressive photo if you had the planet Saturn in the foreground :) \$\endgroup\$ Apr 27, 2021 at 17:59
    \$\begingroup\$ perhaps pin carrier ... you could simply pull pins from a pin header \$\endgroup\$
    – jsotola
    Apr 27, 2021 at 18:10
    \$\begingroup\$ @AndrewMorton Did you mean Jupiter maybe? \$\endgroup\$ Apr 27, 2021 at 21:40
  • \$\begingroup\$ Did you ever manage to find pin ``` housing/insulators```? I would love to order some but cannot find any anywhere. If so, what name did you use for the plastic item of the pin headers? \$\endgroup\$
    – Misha
    Mar 27, 2022 at 16:48
In some datasheets it is a "bandolier", and this is the most common term I've encountered when it's called anything. In other documentation it is just "Insulator", and bandolier can refer to another carrier. (I know this is an old question, but this question didn't have a correct answer). I don't think I've ever seen a way to order just the bandolier, but maybe if you contact a supplier of pin row header (like Semtek), they might be able to offer something. That said, it's possible to order a variety of header lengths & features, so that might be easier than adding bandoliers.
I don't understand the stacking headers a bit too long comment. Also I was not able to find anything in https://www.digikey.ca/en/products/filter/rectangular-connectors-housings/319 or https://www.digikey.ca/en/products/filter/rectangular-connectors-accessories/340 matching this description, not that such a search would be on-topic - EESE is somewhat strict on the non-shopping policy.
Manufacturers of pin headers typically call this the insulator or housing, made out of nylon or glass-reinforced PBT thermoplastic.
In production I think it'd be rare to need this kind of thing - a spacer with no populated pins - since you'd want the pins prepopulated to reduce assembly labour.
