I'm working on a toy device that goes into an airplane. It is using a BLE device and yet my knowledge about is a quite limited.
If I understood correctly, usually in protocols: the device advertise, the central connects and communicate. But if a disconnection happens (for instance my phone goes into flight mode), is it possible to be sure that the device doesn't send any data?(no advertising)
And more important: since I've been connected once, can my device just passively wait some incoming data to reconnect ? (the landing is done, my phone is active again. Thus I want to reconnect to my device without pushing any button)
I couldn't find any flowchart explaining this situation. Maybe that are silly questions but I cannot find the answer clearly.
Thanks a lot!
  • \$\begingroup\$ Refer to the Bluetooth specs. They’re available from Bluetooth sig. \$\endgroup\$
    – Kartman
    Apr 28, 2021 at 11:30
Nope. A BTLE peripherial must advertize in order to be found and re-connected.
Thus your device needs an OFF switch for strict airplane compliance.
  • \$\begingroup\$ Hi, thanks a lot for your answer. After several web search, I think you are right. It still seems to be a bit fuzzy, usage restrictions vary by airline. \$\endgroup\$
    – robotsmith
    Apr 29, 2021 at 20:03
