I want to add a reverse-polarity diode to my design.
It has an input of 24 V (230 Vac to 24 V power supply) which is fed to a 24 to 12 V converter. I plan to draw up to 4 A from the 24 V power supply. The PCB works in a generally room temperature environment and has an SBC, mini pcie port and an RS-485 comm line.
I was planning on adding a diode with a serial fuse too, in parallel to the 24 V in order to prevent reverse-polarity connection damage.
I also want to add a surge protection to the same power terminal.
  • Can I just use a TVS (bidirectional or unidirectional) instead of the diode?
  • Do I need to have both?
  • I know that a TVS adds a substantial amount of input capacitance. Should I be worried about it?
  • Do I need to have other things in mind, when designing the circuit?
@metsik: Below is an NMOS circuit example for reverse polarity protection. You can see that this is simply a mirror of the PMOS circuit posted by Lundin.
I recommend using a 10V Zener so as to protect the FET gate. This is enough to fully saturate the FET, without getting close to the max Vgs (usually 20V).
Do you need hot-swap protection on this circuit? I would submit you only need it if you are switching this circuit to a live 24DC supply (hot swapping). Most off-the-shelf supplies can power up into a capacitive load (in a controlled manner). Also, a larger concern than the TVS will be the input capacitance you need to stabilize your flyback.
Without any statistical evidence for it, I think the most common solution for rugged industrial/automotive solutions is a P-MOSFET (with built-in diode) with zener + resistor for polarity protection. Then TVS after that for the sole purpose of getting rid of spikes. Example (component values may be tweaked):
Optionally with a fuse before the MOSFET. N channel versions exist too if you are very picky with Rds(on).
For surges, a big bulk cap is usually good enough for most applications. For the more extreme scenarios with huge surges, there's specialized "surge stopper" power management IC you can use: https://www.analog.com/en/products/monitor-control-protection/surge-stopper-overvoltage-overcurrent-protection.html.
  • \$\begingroup\$ For surges, a big bulk cap is usually good enough - can you expand on this? Having a big bulk cap can actually make inrush worse. \$\endgroup\$
    – Reinderien
    Apr 28, 2021 at 13:47
  • \$\begingroup\$ @Reinderien Oh yeah it gives a huge inrush at power on. But then it typically doesn't matter because you haven't started yet. These caps help from surges when you are already up and running. It's a pain to combine them with fuses though, very delicate balance in that case. \$\endgroup\$
    – Lundin
    Apr 28, 2021 at 14:01
  • \$\begingroup\$ You can also mirror this circuit and use an N-channel mosfet on the return leg if you can tolerate separate grounds. \$\endgroup\$
    – Troutdog
    Apr 28, 2021 at 14:11
  • \$\begingroup\$ @Troutdog I plan on designing a flyback after that protection circuit, so I will have seperate ground either way. how does a protection circuit with an N-MOS look like? does that mean adding a 3rd ground? \$\endgroup\$
    – metsik
    Apr 29, 2021 at 7:06
  • \$\begingroup\$ @Lundin, the velue of the 24v zenner seems to result in a 0v voltage across R1. woldnt it put the PMOS in an ohmic-cutoff state? also, as I see it, the added TVS will result in high inrush current that I wish to avoid. is there another way to aproach it without introducing voltage spikes and high inrush current to my 24- 12v converter? \$\endgroup\$
    – metsik
    Apr 29, 2021 at 7:19
