I want to run an LTSpice simulation with data acquired from an actual, real circuit. I have multiple files containing data from different scenarios and I need to consider them all. Is there a way to run the simulation multiple times, using data from a different file each time?
Here's a simplified schematic to illustrate what I've tried - it doesn't work (I get an error: Could not open file "c:\data" in PWL):
The folder C:\Data\ contains ten files, named 10.txt, 20.txt, ..., 100.txt. The sim works fine if I specify an actual file name in PWL file.
Any suggestions how I can make this work? It would really help my task to see the data from the various scenarious (different motor speeds) in one diagram.
Thanks a lot!
merendo
