I have been designing a circuit that involves a 5V DC Fan. When I was creating the schematic on EagleCAD, I couldn't find something that resembles a Fan other than a Motor. Should I stick with using a motor, or should I opt to find a library that contains a much more intended symbol for a fan elsewhere?
TIA
  • \$\begingroup\$ What do you intend to do with the schematic? Normally we would add a component that is the connector for the fan, not a component for the fan itself. That assumes that you want to build a PCB from the Eagle design. \$\endgroup\$ Commented Apr 29, 2021 at 22:24
  • \$\begingroup\$ @ElliotAlderson At the moment, the system is still at the prototype stage. I need the schematic to submit it along with the system so it has to be clear as much as possible. \$\endgroup\$
    – gann
    Commented Apr 29, 2021 at 22:27
  • \$\begingroup\$ The steady state load for any 5V fan looks like a resistor with surges depending the rate of change of voltage. \$\endgroup\$
    – D.A.S.
    Commented Apr 30, 2021 at 2:32
You forgetting the third and simplest option - just create your own symbol. You can also add connector footprint for it to be ready for PCB design.
Seriously, I don't recall any more or less complex projects where I did not need at least one custom element.
