Hi everyone one more time, I have a silly question about trace length measurement on Altium. I was using the PCB tab to measure the length of the traces (on mm). Measuring PCIE_REFCLK_P on the tab de value is 14.072.
But I realized that If I use Reports>Measure selected objects I see this:
The measurement is almost 4 mm less, which is the good measurement or the measurement I should to use? Thank you so much!
  • \$\begingroup\$ Is your question the difference between mm and mil? If so, because the USA insists on using nonsense units, we're stuck with a bastardisation of metric and imperial: the mil! One mil is 1000th of an inch, so your numbers are the same. \$\endgroup\$
    – awjlogan
    Apr 30, 2021 at 8:16
  • \$\begingroup\$ No, Is that not the question, and not the same numbers. On PCB tab PCIE_REFCLK_P length is 14.072 as "Routed". Using Reports > Measure select objects the length is 10.741 mm. \$\endgroup\$
    – Juanma
    Apr 30, 2021 at 8:27
    \$\begingroup\$ Got it, that needed clarifying :) \$\endgroup\$
    – awjlogan
    Apr 30, 2021 at 8:31
  • \$\begingroup\$ Sorry for the misunderstanding, I´m going to edit the post. \$\endgroup\$
    – Juanma
    Apr 30, 2021 at 8:32
    \$\begingroup\$ On an unrelated note, I don't recommend putting vias that large over SMT pads that small. Solder will wick through the via barrel and will not flow properly around the component leads, causing a poor (or nonexistent) joint \$\endgroup\$
    – DerStrom8
    Apr 30, 2021 at 11:16
Net length takes vias in account.
Via length is equal to PCB thickness according to ALtium.
Net Length = Distance measured (with Reports>Measure) + Number of vias * PCB thickness
  • \$\begingroup\$ Thank you so much! I was afraid because I have used the Net Routed Value. \$\endgroup\$
    – Juanma
    Apr 30, 2021 at 12:44
