I want to develop a circuit which can detect electromagnetic waves (radio wave, microwaves.)
This circuit will just act as a tamper detect and not physically measure/compute the radiation.
I have designed the circuit using a toroid ring and a few Schottky diodes.
The calculation formulas and schematic diagram are in the attachment.
After testing the circuit, I'm not getting any output.
Hence, I wanted to get the circuit as well as the calculation part of it verified.
Please note that the WAVE_SENSE signal in the design is connected to a 10-bit ADC of a microcontroller.
  • \$\begingroup\$ Are you expecting the coil to receive microwaves? If so, you can give up on that. It won't work at the frequencies you are interested in. \$\endgroup\$ – JRE Apr 30 at 9:46
  • \$\begingroup\$ Toroids are closed loops, they tend to cancel outside fields. ie. they do not make good antennas. \$\endgroup\$ – Aaron Apr 30 at 18:00
  1. Your coil won't be responsive at the frequencies you are interested in. I don't have the math to figure it, but I have some experience as a technician with radio frequency circuits. That coil on that core will probably do a dandy job of filtering microwave signals out of your receiver.
  2. Those diodes probably won't work at microwave frequencies, either. The BAT43 datasheet only mentions frequencies twice: 1MHz and 45MHz. That diode isn't made for GHz frequencies like you will need to detect microwaves.
  • You need a better diode. I have used the BAT63 for a similar project.
  • You need an antenna instead of that coil. I used a simple dipole antenna. Just two equal length wires of approximately 1/4 the wavelength of the operating frequency you are interested in.
The circuit that I built used a sort of voltage multiplier to drive a few LEDs to indicate the RF level.
It looked like this:
You could simplify it to this:
Use two wires of about 3 centimeter length as antennas connected to P1 and P2. 3 centimeters is approximately correct for 2.5GHz. That's about 1/4 the wavelength of 2.5GHz.
  • \$\begingroup\$ Thankyou JRE, Looks like a circuit worth testing. \$\endgroup\$ – Pralay Panchwate Apr 30 at 12:21
    \$\begingroup\$ @PralayPanchwate: Keep in mind that you can't build this on a solderless breadboard. High frequency stufff does not play nice with solderless breadboards. The BAT63 is purely a surface mount part, and you want to use surface mount parts for the capacitors as well. I used size 0201 SMD capacitors for the 10pF parts. \$\endgroup\$ – JRE Apr 30 at 13:14
