-1
I have a 12V/24V dimmer (rated 60W) and need to hook up 8 different lights, can I just use a regular power strip to distribute the 12V/24V? the power strip of course says 230V on it, but does it function right with 1/10th of that?
    \$\begingroup\$ Don't use plugs and sockets designated for mains for other voltages. Someone will plug one of your low-voltage devices into a mains socket. \$\endgroup\$
    – Transistor
    Commented May 1, 2021 at 21:22
  • \$\begingroup\$ yeah I mean obviously I would't put the lights into the actual wall socket, just the power strip when it's on the dimmer 12V/24V. I just need something to split the dimmer output and I already have a power strip with switch and led and everything so why get seperate new 12V stuff for it if that can work with less power...I'm not going to give this to anybody else \$\endgroup\$
    – HelpIIII
    Commented May 1, 2021 at 21:26
    \$\begingroup\$ Nothing is obvious from your question which isn't very well written. You can edit to improve it. Draw a diagram of what you are proposing. Remember that you're on an international site and there is no location information in your question or in your user profile. Words like "power strip" mean different things in different countries. \$\endgroup\$
    – Transistor
    Commented May 1, 2021 at 21:30
  • 6
    \$\begingroup\$ How do you know you won't put the lights into an actual wall socket? That is the obvious thing to do. Anyone will do it - including others in your house, and yourself after you forget. \$\endgroup\$ Commented May 1, 2021 at 21:47
    \$\begingroup\$ @HelpImStupid One more thing to consider is that a power strip is usually rated for one current. For example, in the US often this is \$15\:\text{A}\$. But not necessarily. Even assuming you want to just ignore the advice against using mains outlets for DC for safety reasons, the wiring in the power strip can be absolutely scarily "thin" and flimsy. (I should show you a picture of one I have here, had I the time.) AC also self-extinguishes arcs, while when you plug in your DC devices the arcing will be excessive compared to design intent. And for the same power, your DC will require more amps. \$\endgroup\$
    – jonk
    Commented May 1, 2021 at 21:51
It will function, but using standard plugs and sockets for the wrong voltage is a spectacularly bad idea. This relies on you being in total control, remembering everything about your setup forever, and making no blunders...
Every novice goes "oh, I can handle that"... but that is simply not realistic, and the standards bodies who set electrical safety rules know that which is why they do not allow it.
Most 230V appliances won't do much if plugged into a 12/24V source... the bigger problem is the reverse, nothing keeps anyone from plugging your 12/24V light into an AC mains socket and starting a fire, or killing someone if the light is not up to the standards required to handle 230V safely.
You should use whatever connector standards exist in your country for the voltage you are handling. There are many such standards for 12V. For 24V, you may need to improvise something with electronics-supply-house connectors. As long as it's far away from any conflicting standards, that should be fine. Nothing from the AC mains parts bin should be used for this, despite how easy it is.
Or heck, you can simply merge a gob of wires on a terminal block. That is better than using incompatible connectors.
  • \$\begingroup\$ Wish I could upvote this multiple times. Your answer probably saves people from serious pain. \$\endgroup\$ Commented May 1, 2021 at 22:18
  • \$\begingroup\$ It's worth mentioning that many switches and relays, though I'm not sure I've seen it on connectors, have a minimum voltage/current as well. The contacts oxidize, and you can get high contact resistance until enough current flows, or more usually a spark happens, to break the oxide layer and lower the contact resistance. \$\endgroup\$
    – Hearth
    Commented May 1, 2021 at 22:19
