The part https://www.digikey.com/en/products/detail/mpd-memory-protection-devices/ZA1030/2439603?s=N4IgTCBcDaIF4EMCMAGAzCgtAOwCYgF0BfIA
and the drawing https://www.memoryprotectiondevices.com/datasheets/ZA1030-datasheet.pdf
How do you wire this plug? Is there an additional set of ferrules/supporting parts or crimping tools needed? Solder wets fine, but will cold work.
    \$\begingroup\$ i have opened four or five of these in the past ... they were all connected the same way ... fold wire over item 4 and solder ... solder end of wire to inside of item 1 .... some power plugs had a built-in inline fuse connected to item 1 at one end ... the wire was sodered to the other end of fuse \$\endgroup\$ – jsotola May 3 at 15:46
This is how it is done in a commercial product (12V compressor): enter image description here
So soldering it seems to be the correct way. The minus wire is wrapped around that metal piece before soldering.
