enter image description here Just need help in the daigram of this sum. Can't understand the daigram.will a common resistance be shared between capacitor and inductor or is there 2 resistor and 1 capacitor and inductor with resistance connected with each
  • \$\begingroup\$ tinyurl.com/yj27hqy4 not correct values \$\endgroup\$ – Tony Stewart EE75 May 4 at 11:41
  • \$\begingroup\$ Since the voltages are measured separately across the inductor and capacitor (100 V, 125 V), total of three resistors would need to be modeled it seems. \$\endgroup\$ – AJN May 4 at 11:43
Well, according to the description we have:
  • \$\begingroup\$ R1 should go between L & C to avoid Vi getting in the middle to question \$\endgroup\$ – Tony Stewart EE75 May 4 at 11:42
  • \$\begingroup\$ Sir the voltage across resistance which is given as 150v is seperate resisitor and not the resisitor part of L or C right? \$\endgroup\$ – Kalpit prabhu May 4 at 12:02
