I am currently using ZXCT1009 high side monitor for monitoring the current consumption on a bus line for an embedded system we are developing. I am currently using tek scope with Labview for automation purpose. Works good at our lab.
Now I am thinking of implementing this ZXCT1009 in the embedded design itself and somehow sensing the voltage across the output resistor.
ZXCT1009 data sheet -http://www.diodes.com/datasheets/ZXCT1009.pdf
I am not sure how to move forward along the lines of using ZXCT1009 as a battery current monitor.
