I have come across the schematic below, and I am unsure why there is a resistor across VIN to GND on the AP2205 5V voltage regulator. Why might this be?
Note: This is for an isolated CAN circuit where the CAN transceiver draws it's power from the CANBUS.
Schematic
  • 5
    \$\begingroup\$ It looks quite strange - particularly the 1% specification but that might be a default on the drawing package. It might be required to discharge the capacitors when powered down. \$\endgroup\$ – Transistor May 4 at 13:28
    \$\begingroup\$ The data sheet shows a resistor in series with a cap to control startup time, but that doesn't apply here. \$\endgroup\$ – Scott Seidman May 4 at 13:30
  • 6
    \$\begingroup\$ The interesting thing about random schematics of unknown origin is that these might be simply incorrect. \$\endgroup\$ – Eugene Sh. May 4 at 13:36
  • \$\begingroup\$ Yes I saw that in the datasheet, but that doesn't apply here as you say. It could be capacitor discharge. \$\endgroup\$ – Orca_StackOverflow May 4 at 13:36
    \$\begingroup\$ @glen_geek you may be right ... there may have been a switch between Vin and EN' ... someone removed the switch and left the resistor \$\endgroup\$ – jsotola May 4 at 14:23
