How is the nominal voltage of a battery determined?
A NiMH cell's usable voltage ranges between around 1.4-1.0V and the nominal voltage is quite in the middle of that at 1.2V.
Similarly, the nominal voltage of a LiPo is given most of the time between 3.7V and 3.9V, with the usable voltage being between 3.0V-3.5V and 4.2V-4.6V. So again, the nominal voltage looks to be in the middle of the usable voltage.
But for Alkaline cells the nominal voltage of 1.5V is at the very top end of the usable voltage of 1.6V to 1V.
So how is the nominal voltage determined, and is there a difference between primary and rechargable cells?
To clarify the question because there are a few answers that apparently misunderstood the question.
On some chemistries the nominal voltage is close to the maximum voltage of the cell (e.g Alkaline with 1.5V, where a fully-charged cell has 1.6V), while others have their nominal voltage at the average charge (e.g. NiMH at 1.2V or LiPo at ~3.8V).
Why are some nominal voltages close to fully-charged voltage, while others have are at 50% charge? Is the difference that primary cells have their nominal voltage at 100% and rechargable cells have it at 50%?
I am NOT looking for answers to those questions:
  • How can I find out the nominal voltage of a battery?
  • Why have different chemistries different voltages?
  • What are primary/rechargable cells?
  • \$\begingroup\$ If you take any battery, and test it, getting the discharge curve, then the nominal voltage will answer the question, "when you simplify, where does this battery voltage spend most of its time, and what is the median (middle) of that range, so we can give a single value, a simplified answer of what voltage this battery delivers." So, what actually determines that is the actual chemistry of the battery, and the battery itself. \$\endgroup\$ Commented May 5, 2021 at 21:41
The nominal voltage of a battery is not determined. It is specified.
If there was such a thing as 'nominal voltage' that could be measured, then it could determined by measurement.
The clue is in the name 'nominal'. Amongst its meanings are 'existing in name only' and 'within expected and acceptable limits'. It's a convenient way of summarising the cell's performance, and is not meaningful for any practical evaluation of the cell, or design for equipment using it.
If a rechargable battery has a voltage at which it delivers most of its stored energy, then that tends to get picked for the 'nominal' voltage, so 2 v for lead and 1.2 v for nickel chemistries, otherwise 'somewhere between max and min' is all you can do. Below 1.2 v, there's very little deliverable energy left in a nickel cell.
The choice of 1.5 v for the nominal voltage for alkaline cells has driven the market for using these cells in a bad direction. There are far too many AA-using devices that say 'battery low' when down to only 1.2 v or even 1.3 v. When I was in engineering in a professional scientific instrument company, our internal rule was that battery-driven products had to work down to 0.75 v per cell. Perhaps that was excessive, but there's still quite a lot of energy to deliver from an alkaline cell between 1.2 v and 1 v, which would be a more reasonable lower limit.
  • \$\begingroup\$ So there is no real rule of what "nominal voltage" really means, except that it's somewhere in the usable voltage range? That's kinda disappointing... Thanks for the detailled answer, though. The reason I was asking is I built a little circuit using parts that can withstand up to 5.5V. So I took 4 AA NiMH, because 4*1.2V=4.8V, which is fine. But, turns out, each cell had 1.45V, so 5.8V in total and my Microcontroller is fried now... \$\endgroup\$
    – Dakkaron
    Commented May 5, 2021 at 19:43
    \$\begingroup\$ @Dakkaron Sorry to hear that. As I said in my answer, 'not meaningful for ... design for equipment using it.'. You have to design to the max and min voltages from the cell. \$\endgroup\$
    – Neil_UK
    Commented May 5, 2021 at 19:46
  • \$\begingroup\$ Thank you for that info. Before digging into that, I thought, that NiMH had the nominal voltage at the top, like Alkaline. But it's just another pitfall for the non-educated, I guess^^ \$\endgroup\$
    – Dakkaron
    Commented May 5, 2021 at 19:52
    \$\begingroup\$ @Dakkaron 'A part that can withstand 5.5 v' should probably be operated at a maximum of 5 v anyway. That 5.5 v absolute max spec will not allow for any uncertainties if you try to operate it at 5.5 v. The recommended 5 v (I'll bet that was the max recommended!) allows for measurement uncertainty, setting uncertainty in any voltage regulators, and maybe the odd bit of overshoot. \$\endgroup\$
    – Neil_UK
    Commented May 6, 2021 at 13:16
  • \$\begingroup\$ With at least LFP battery chemistries, I often observe from their datasheets that V = E / C applies, where V is the nominal Voltage, E is the nominal battery capacity in Watt-hours and C is the nominal battery capacity in Ampere-hours. These nominal values correspond to a nominal discharge current, in turn corresponding to a prescribed nominal "C-rate" (usually 0.2) at room temperature. For example, a C-rate of 0.2 for a 100Ah battery gives 0.2 x 100Ah = 20A discharge current. \$\endgroup\$ Commented Nov 29, 2022 at 3:39
You determine the nominal voltage of a cell by reading the manufacturer's datasheet.
That information is derived from the design and chemistry of the cell or battery. Different chemistries (i.e. carbon-zinc, lead-acid, LiIon, LiPo, etc.) generate different potentials which ultimately determined the nominal voltage.
As far as primary vs. rechargeable, a primary battery or cell is non-rechargeable.
  • \$\begingroup\$ This doesn't really answer the question. The question was "Why are the nominal voltages of some chemistries at the top of their usable voltage, while some are in the middle?" \$\endgroup\$
    – Dakkaron
    Commented May 5, 2021 at 19:44
