I am designing simple logic analyzer with SN74LVC16T245DGGR bus transceiver which could be used for 1.2V to 5V logic levels I would like to control supply voltage of input port with DAC, currently TLV5624, but this DAC could deliver only 1mA current and I doubt that it's enough for transceiver so I put LM321 OPAMP but this OPAMP has 1.5V voltage drop so with 5V supply I can get only to 3.5V which doesn't enable me to interface 5V logic.
Is there any single supply OPAMP with lower voltage drop? I would need to get to at least 4.5V. And using some charge pump to get higher supply voltage is not the way for me, because it should be USB powered and I don't want to have high power consumption.
Or would it be better to control feedback of some buck voltage regulator with DAC? It seemed to me as overkill to use voltage regulator for this with all inductors and capacitors and I think that these regulators have high voltage drop as well.
