What is this symbol?
I couldn't decide whether it's a solder bridge or not.
schematic of a Low noise diode laser current controller
12
That's a coaxial cable. The "broken" section in the middle symbolizes "very long".
Given that it feeds the laser diode and must not be a short circuit the symbol seems to represent a coaxial cable connection. It looks a little childish because the perspective is wrong at one end or the other.
  • \$\begingroup\$ it is not supposed to be a representation of a 3D object view ... because the RF connector symbols are used, it is unclear if the coax cable is soldered into the circuit, or if connectors are used \$\endgroup\$
    – jsotola
    May 8, 2021 at 0:03
