I have made two H-bridges following this schematic.
I have replaced:
TIP107 with TIP147
TIP102 with TIP142
The opto-couplers are P785.
I have not included the diodes as they are internal to the TIP.
I am trying to run two small toy car motors, max 2 A. The power supply is 20 V isolated. The plan is to PWM the ENA signal with an Arduino to adjust the voltage to the motors.
Everything seems to work just fine on the bench. However, after a few minutes of running and stalling under load, the TIP seem to get quite hot and the motors stop responding in the direction the stall happened. The other side seems to be unaffected. When trying again after a few minutes, the affected side just gets hot, but no motion from the motor, while the unaffected side seems to work fine.
I have already replaced the TIPs a few times, a multimeter test shows some transistors don't turn off anymore, and the last time both PNPs had continuity between collector and emitter with all power off.
I went over and over the control circuit, there seems to be no problem there. Is there anything I might be getting wrong? I have to invert the PWM value in the code:
PWMValue = (255 - PWMValue)
as the sides are actually active when ENA is low, so I am not sure if this is causing any problems, but as I said, without load the motors run just fine.
