I am trying to make a PCB with STM32 L412KB . Data sheet says it can use a crystal of 4 MHz - 48 MHz. But when I initialize the HSE under RCC option in Cubemx I get only one pin as RCC_CK_IN and no RCC_CK_OUT. However, LSE crystal highlights two pins.
Does it require special kind of oscillator or is there a bug or error in datasheet or software?
https://www.mouser.in/datasheet/2/389/dm00481909-1799148.pdf
edit: schematic image from nucleo board
    \$\begingroup\$ "One-pin OSC in" suggests that Cubemx is expecting you to provide an external oscillator rather than a crystal for its internal HSC (which requires 2 pins). An external oscillator is connected to OSCin pin, and to GND (Vss). This chip has TWO oscillator domains - are you confusing them...(HSE vs. LSE)? \$\endgroup\$
    – glen_geek
    May 8, 2021 at 14:24
  • \$\begingroup\$ @glen_geek Data sheet says, it can use high speed external crystal or ceramic resonator. I've referred nucleo board schematic using same MCU, LSE OUT appears to be shared. \$\endgroup\$
    – Mridul
    May 8, 2021 at 14:37
  • \$\begingroup\$ The datasheet, table 14, page 56, shows that PH0 and PH1 are the pins for an external high-speed crystal - but these are not available on all package options (only the 48- and 64-pin versions). Which package are you using? \$\endgroup\$
    – brhans
    May 8, 2021 at 14:46
  • \$\begingroup\$ @brhans its a UFQFPN32 package. I would normally use f103 chip but current IC shortage has forced me to consider L412 \$\endgroup\$
    – Mridul
    May 8, 2021 at 14:53
  • \$\begingroup\$ Well, there's your answer. 32-pin package for the L412 has no external HSE crystal option. If you refer back to the datasheet to page 57 you'll see that the 32-pin packages use PA0 as an option for the HSE, but that's for an external oscillator, not a crystal. It's labelled 'CK_IN' compared to PH0/PH1 labelled as 'OSC_IN/OSC_OUT' because they're connected to the IC's internal oscillator (which the 32-pin package doesn't have). \$\endgroup\$
    – brhans
    May 8, 2021 at 15:02
Since you are using Nucleo, the MCU that handles the ST-LINK debugging has the crystal oscillator, and it provides a square wave clock out to the target MCU. It is the MCO pin that can fed to two pins in the target MCU.
