I am trying to design a 1 DOF copter as in this drawing: enter image description here
For this circuit there is a stick connected to a DC motor and potentiometer. The potetiometer can be rotated. I need to control the position of the motor with analaog PID circuit using another potentiometer.
My PID circuit is as below:
The first potentiometer controls the angle. The output potentiometer should give feedback.
I am newbie and this circuit does not work, that means my motor does not work when I supply power.
I checked without the motor connected. There is a voltage and everything is okay but after connecting the motor, the voltage is zero and the system does not work.
Because of the pandemic situation, I cannot use the lab equipment to power supply. I think there is not enough current.
  • How can I increase the current?
  • How can I make sure the PID circuit is working correctly?
Some information my circuit components:
  • All op-amps UA741cp
  • Other component same with the designed circuit in picture
  • My motor is 820 coreless brushed motor set 3.3V =35000-37000 RPM, 5V = 50000 RPM , Size:8 x 20mm, working current min = 0.15A, weight 6.5gr
    \$\begingroup\$ There's no way you can drive that motor directly from the opamp output. The 741 can deliver a few milliamperes at most. The motor needs much more current than that. \$\endgroup\$ – JRE May 8 at 17:07
  • \$\begingroup\$ Do you suggest an opamp type? \$\endgroup\$ – Kerim Turak May 8 at 17:31
    \$\begingroup\$ There's multiple things wrong with that circuit. Please edit your question with a revised schematic that shows how the op-amps are getting power, and where the motor is in the circuit. Do you even have power to the op-amps? \$\endgroup\$ – TimWescott May 8 at 17:33
  • \$\begingroup\$ Okay! I updated the schema and it works very well right now in simulation. Now I will set up the reality of the scheme. \$\endgroup\$ – Kerim Turak May 8 at 17:40
To increase the current, I suggest to use PWM-signal by using output (voltage) signal compare with saw-tooth or triangle signal. Then you can feed PWM signal to Motor drive module or FET to drive motor. This PWM method produce less heat compare linear method.
If you really want to drive motor with voltage you can try linear voltage regulator with loss a lot of power to heat as follow.
If you want to make sure that your PID control work currectly , you can test open-loop response with signal generator and osciloscope.
  • \$\begingroup\$ This comment was very useful for my research, thanks. \$\endgroup\$ – Kerim Turak May 8 at 19:20
  • \$\begingroup\$ Please add a flyback diode across the motor. \$\endgroup\$ – winny Jul 23 at 21:05
High current from an op amp with or without transistors?
As for testing. Break the problem down into sections and test each section. To test the control loop, that gets a bit tricky, so start with just the P term. Then add the I term. The D term is last. Adjust the coefficients at each stage.
Understand that adjusting a real PID system is not trivial, so expect to make mistakes.
  • \$\begingroup\$ Thank you for your valuable comment, I will add it here as a reply when I complete the system, but what a voltage source and current value should I have in order to run this circuit, I cannot reach the laboratory due to the pandemic. Now I have a small source that gives current up to 12v and 1 amp, I will get a stronger one, I would be glad if you have suggestions as a component (op-amp type). \$\endgroup\$ – Kerim Turak May 8 at 17:38
This circuit works well for me. I use five LM741 op-amps and one power BJT for motor driving.
