Your mistake is again the current direction.
For \$V_1\$ node you have wrote:
$$+12A + \frac{V_1 - V_2}{2\Omega}....= 0$$
As we can see from a circuit diagram the \$12A\$ current is entering the node(incoming current).
But we have a problem here because you decided to give a "+" for 2 ohms resistor current as well.
But this notation \$\frac{V_1 - V_2}{2\Omega}\$ imposes the current direction. And this current direction is from \$V_1\$ to \$V_3\$ (the current is flowing out of the node).
And here we have an error in your current direction assumption. And this is why you are getting the wrong answer.
The correct equation should look like this:
$$-12A + \frac{V_1 - V_2}{2\Omega} + \frac{V_1 - V_3}{4\Omega} = 0$$
$$\frac{V_2}{4\Omega} + \frac{V_2 - V_1}{2\Omega} + \frac{V_2 - V_3}{8\Omega} = 0$$
$$ 2\times\frac{V_1 - V_2}{2\Omega} + \frac{V_3 - V_1}{4\Omega} + \frac{V_3 - V_2}{8\Omega} = 0$$
Or like this (not recommended way):
$$+12A + \frac{V_2 - V_1}{2\Omega} + \frac{V_3 - V_1}{4\Omega} = 0$$
$$\frac{V_2}{4\Omega} + \frac{V_2 - V_1}{2\Omega} +\frac{V_2 - V_3}{8\Omega} = 0$$
$$ 2\times\frac{V_1 - V_2}{2\Omega} +\frac{V_3 - V_1}{4\Omega}+\frac{V_3 - V_2}{8\Omega} = 0$$
missing in middle equation ? The source is2 ix
.(V1 - V2)/2
is only1ix
? Also mark the reference direction ofix
in the diagram. It seems to be marked 2 different ways in the current diagram. \$\endgroup\$ix
reference direction clearly marked ? \$\endgroup\$
