I think I didn't explain myself correctly. Let me tell you in more detail.
I have 64 blocks: A, B, C, D ..... Each of these blocks is a parallel in parallel out shift register of n bits. The task of these blocks is to shift their contents from A to B, B to C, C to D..etc.
I'm having trouble sending the std_logic_vector type of data from one block to the other.
My code is given below. I've put comments on the lines that have the error.
library ieee;
use ieee.std_logic_1164.all;
entity Shift is
generic (
  Block_Size         : integer := 64;
  Entry_length       : integer := 32
port(
  new_entry:      in std_logic_vector(Entry_length-1 downto 0);
  clk:            in std_logic;
  reset:          in std_logic;
  done:           out std_logic
end Shift;
architecture Synchronous of Shift is
component ShiftReg
      generic (
      port(
          clk:            in std_logic;
          enable:         in std_logic;
          data_in:        in std_logic_vector(Entry_length-1 downto 0);
          data_out:       out std_logic_vector(Entry_length-1 downto 0)
end component;
signal data_Shift_i : std_logic_vector(Entry_length-1 downto 0);
signal enable : std_logic;
begin
  Reg_i: for i in 0 to Block_Size-1 generate
            i_Reg: ShiftReg
            generic map ( Entry_length => Entry_length
            port map (
                clk              => clk,
                reset            => reset,
                enable           => enable,
                data_in          => data_Shift_i(i-1),  -- error: cannot put (i-1)
                data_out         => data_Shift_i(i)     --error: cannot put (i)
  end generate Reg_i;
end synchronous;
You can put the components A and B in a new component (e.g. AB) and instantiate that new component n times with a generate.
gen: for i in 1 to 64 generate
   i_ab: entity work.ab
      port map(
end generate gen;
| improve this answer | |
  • \$\begingroup\$ I think I didn't explain myself correctly. Let me tell you in more detail. \$\endgroup\$ – Orange Feb 3 '13 at 7:49
There is a problem with the binding of your ports to the signal. The ports are 32 bits wide. Your signal at toplevel who is connecting e.g. A with B is also 32 bits, but you're using only one bit for the connection!
I would create a new type:
type t_interconnect is array (0 to Block_Size) of std_logic_vector(Entry_length-1 downto 0); -- the new type
signal interconnect of t_interconnect; -- the signal of the new type to be used
You can assign the input of the topmodule to the first index of 'interconnect'. And further connect the 'data_in' and 'data_out' as in the example. The last index of the array is then the output of the last module in the chain and should be assigned to the output of the toplevel.
  • \$\begingroup\$ Thank you Vermaete! That was really helpful. I have another question regarding this: If i want to initialize all the blocks with a value, ie data_in of each of them will get a Entry_lenngth bit unique value. I have another program which generates random numbers every clock cycle (So it needs to be inside a process). How can I loop through all the components at each clock cycle and initialise them with the values? \$\endgroup\$ – Orange Feb 6 '13 at 14:30
data_Shift_i is only 32 bits wide. Your for loop goes from 0 to 63 so you are trying to access bits of data_Shift_i that don't exist. However, I think that is just the first of your problems.
