I am working on detecting the amplitude of a signal coming from a guitar pickup. I am using an esp32 and an LM386 module for amplifying the signal.
I get quite stable readings with a multimeter, but the readings on the Arduino IDE show peaks and also peaks come when no signal should be there.
Arduino IDE Readings
Here is a link for short videos of both the esp32 readings and the multimeter:
https://drive.google.com/drive/folders/1gpvkN_sz627jG0TNPpUps82105EB89OF?usp=sharing
Thanks!
Simple code:
int ampedVoltagePin = 12;
void setup() {
  pinMode(ampedVoltagePin, INPUT);
  Serial.begin(9600);
void loop() {
  Serial.println(analogRead(ampedVoltagePin));
  delay(100);
Diagram:
Diagram
0.1 Hz is not enough to measure audible frequencies. You need to get at least double the sampling frequency for the signal you measure. See also: https://en.wikipedia.org/wiki/Nyquist_frequency
Say you have 500 Hz, then you need to sample at least 1000 Hz, or 1 ms. Then you can attempt peak detection.
