Question
The OP has so far fried four motor drivers. He wishes to know what went wrong, and how to avoid frying more motor drivers.
Answer
Part A - Analysis of the the OP's motor and motor drivers
- We will first study his motor and motor drivers, and then guess what went wrong.
Uxcell JFC63R Gear Motor (Appendix A)
My first impression is that it is a very powerful motor. I usually first look at the motor shaft. The shaft is 10mm diameter, which is for very powerful motors. The power is 80W, an of course is very powerful. This implies big current is need to drive this motor, and that the back EMF, which is proportional to the square of the motor current, is huge, and needs a powerful and fast Schottky flyback diode to absorb the motor's inductive energy, when the motor current is switched off.
Another implication is that even with light load, the motor might not move, and the stall current would be many times of the operating current, and the motor driver might easily get fried, if there is no over current and over temperature protection.
Cryton 80W, 13A Motor Drive MD13S (Appendix B)
The Cryton MD13S looks OK, except it can only handle max 13A continuously. As mentioned earlier, this motor stall current may exceed 13A, this overheating the driver and fry it.
Niyito 170W, 110A Motor Driver (Appendix C)
The current rating looks OK. However, there is heat sink used, which might be problematic, if there is no temperature protection.
Part B - Suggestion to the OP and other motor newbies
The OP appears to have thrown himself at the deep end of the swimming pool. I would suggest to start learning at the shallow end, ie cheapy motor drivers and motors such as L298N H-bridge motor driver, and TT130 toy motor.
The good thing is that the basic principles of H-bridge drivers are almost identical, no matter current rating. In other words, almost all knowledge and skills can directly transfer when switching to industrial/professional grade stuff.
So, after gaining experience and confidence, he can then try high end motor drivers such as BTN7971B (45V, 50A), and not so powerful (therefore not so easily fried! :)) motors such as JGB37-520 (12V, 350mA), as described in this motor newbie tutorial.
References
(1) Uxcell DC24V 80W 100RPM 8NM 10mm Reversible Worm Gear Motor High Torque Speed Reducing Electric Gearbox Motor-JCF63R - Amazon
(2) Cytron 13A DC Motor Driver MD13S - Amazon
(3) Noyito 170W 2-Channel 3.3V/5V Logic input PWM H-bridge Motor Drive Module - Amazon
(4) Pololu G2 High-Power Motor Driver 24v13 - Pololu
(5) How to use motor drivers with H-bridge and PWM input, to control direction and speed of DC motors?
(6) What is back EMF? EESE, Asked 2021apr27, Viewed 714 times
(7) BTS7960/BTN7971B Motor Driver Q&A 1/2
(8) BTS7960/BTN7971B Motor Driver Q&A 2/2
(9) BTN7971B High Current PN Half Bridge (45V, 44A) Datasheet - Infineon 2008jun
(10) Infineon Transportation Brochure (24V to 60V, page 11, DC Motor Control) - Infineon
(11) DC Motor 80W Reviews - AlliExpress
(12) Youtube Video on How to Determine DC Motor Current/Amp Draw (for beginners) — 2014sep13
(13) BTN7971B 6-28V DC Motor Driver Module - AliExpress US$19
(14) L298N Dual H-Bridge Motor Driver User Guide (5V~35V, 2A, 20W, For DC and Stepper Motor) - Handson Tech US$1.5
(15) Pololu G2 High-Power Motor Driver 24v13 (6.5V~40V, 13A without heat sink) US$30 - Pololu
(16) Youtube Video of BTS7960 test 2021apr1601 - 2021apr16
(17) Back EMF Schottky Flyback Diode Selection Notes - Rpi.org.forum 2019jan17
(18) Monitoring and Paralleling L298N H-bridge Motor Current - EESE, 202mar28
(19) 24V DC Worm Gear Motor Catalog (6 pages) - AlliEXpress
(20) Youtube Video Worm Gear Motor Preliminary 12V DC Test - tlfong01 2021may13
(21) Youtube Video of DC Motor Driver Module BTN7971B Test - tlfong01 2021may13
(22) DC Motor 550 775 795 895 DC 12V-36V 2000-15000 RPM - AliExpress
(23) DC Motor 370 Catalog (17 pages) - AliExpress
Appendices
Appendix A - Uxcell Motor
Appendix B - Cytron Motor Driver
Appendix C - Noyito Motor Driver
Appendix D - Old BTS7970/BTN7971B testing images for the OP's reference
- BTN7971b module
- BTN7971B wiring
- BTN7971B testing 1/2
- BTN7971B testing 2/2
- BTS7960 PWM Test
Appendix E - 3V~24V DC Worm Motor
Appendix F - Worm Gear Motor Preliminary Testing Notes
Now I am doing a preliminary test. I used a multimeter to measure the worm gear motor's resistance and found it 28Ω.
So the operating current should be I = V/R = 12V/28Ω ~= 400mA. Then I use a 220VAC to 12VDC 1A PSU to drive the motor.
I found the motor moving slowly, as expected: youtu.be/8RdyY_lDuRQ.
Self promotion disclaimer:
Many of the videos and links in this post are work produced by the post author and are used for self promotion of their external sites.
