I'm building a DIY CNC router. I'm running at a low RPM and only planning on cutting soft materials (wood and under, maybe a PCB).
I'm currently having problems with magnetic interference. When starting the spindle, hard end stops would trigger, and sometimes my controller (arduino) would become unresponsive. For now I've turned off hard end stops, while building the rest of the machine. I'd like to re-enable hard end stops though.
I'm planning on moving my controller further away, and potentially placing it in a metal box. For the end stops however, I'm not sure how to solve it in an as DIY way as possible.
I've got a couple of questions:
  1. How can I measure interference, and below what levels should I stay?
  2. Will it help to simply wrap aluminum foil around my wires and hook that up to ground?
  3. Does it work to hook up shielding to DC ground/zero, or should I hook it up to my AC ground in front of the AC/DC converter?
  4. Where can I find a "beginners guide to magnetic interference"?
  • \$\begingroup\$ Start using a laptop with no charger. Define link all specs, h/w. s/w , full steps? Current limit? UART errors? CNC shield? GRBL code? End stop verified? Link YouTube video \$\endgroup\$
    – D.A.S.
    Commented May 14, 2021 at 17:31
    \$\begingroup\$ how do you know that the problem is caused by magnetic interference? \$\endgroup\$
    – jsotola
    Commented May 14, 2021 at 17:41
  • \$\begingroup\$ @TonyStewartEE75 Thanks for your input. I would be able to provide this information tomorrow, but the problem I'm having is that I can't find any "general" information on this subject. As such, I've tried formulating my questions so that they would help anybody running into similar problems. \$\endgroup\$ Commented May 14, 2021 at 18:47
    \$\begingroup\$ @jsotola Now that you say so, I am not 100% sure. This is my assumption because moving the spindle away from the other wires seems to reduce the chance of it stalling. However, I still want to learn about magnetic interference and shield my systems from it, even if my current problems are not caused by it. \$\endgroup\$ Commented May 14, 2021 at 18:49
  • \$\begingroup\$ how are the end of travel switches wired? ... do they share ground or power paths with the motor? ... in other words, is the sensor ground connected at the motor, or is it connected directly at the main power supply, or somewhere in between? \$\endgroup\$
    – jsotola
    Commented May 14, 2021 at 18:59
the CNC shield and the motor do not share a common ground,
This is one of your problems. A common ground and shield wires for all power and signals is necessary to minimize EMI. A small RF cap help on endStop switches only if you get false signals with NO switches wired correctly.
But avoid multiple SMPS if you can help it as users seem to not know why they have interference. I.e. use a laptop on battery with 1 supply for all CNC for starters.
Reading Henry Ott’s latest book or an older version in Archive.org will take you a few months to learn or longer but well worth it.
I would say shorter if your search skills found my answers here on this site.
  • \$\begingroup\$ Henry Ott or the Grounds for Grounding book, both cover this very well. \$\endgroup\$
    – Aaron
    Commented May 14, 2021 at 23:35
  • \$\begingroup\$ What does your spindle drive consist of? \$\endgroup\$
    – Kartman
    Commented May 15, 2021 at 1:40
  • \$\begingroup\$ Any test results, photos or wiring diagrams yet? \$\endgroup\$
    – D.A.S.
    Commented May 15, 2021 at 17:12
