1st stage
If you set \$\gamma=\frac{C_1}{C_2}\$ and \$\rho=\frac{R_3}{R_4}\$, then the left-side 2nd order filter (1st stage of two) has \$\omega_{_0}=\frac1{R_4\, C_2 \,\sqrt{{\vphantom{M}}\gamma\,\rho}}\$ and \$Q=\frac{\sqrt{{\vphantom{M}}\gamma\,\rho}}{1+\rho}\$.
In the above circuit \$\rho=1\$, so \$\omega_{_0}=\frac1{R_4\, C_2 \,\sqrt{{\vphantom{M}}\gamma}}\$ and \$Q=\frac12\sqrt{{\vphantom{M}}\gamma}\$.
2nd stage
That's followed by a simple RC low-pass filter (2nd stage) that I'm sure you can work out. It should be set to a frequency a little higher, but not too much higher, so as to add another \$20\:\text{db}\$ per decade of roll-off. It will impact \$Q\$, a little. But I didn't want to bother with the derivatives I'd need to work it out for the 3rd order transfer function, so I left that for you.
1st stage transfer function
Using sympy and assigning the shared node between \$R_3\$ and \$R_4\$ the name, \$V_x\$, and the opamp output current as \$I_o\$, the first stage's transfer function is:
zc1 = 1/s/c1
zc2 = 1/s/c2
eq1 = Eq( 0, vi/r2 + vo/zc2 + vx/r3 )
eq2 = Eq( vx/zc1 + vx/r4 + vx/r3, vo/r4 )
eq3 = Eq( vo/r4 + vo/zc2, io + vx/r4 )
ans = solve( [eq1, eq2, eq3], [io, vx, vo] )
tf = simplify( ans[vo]/vi )
tf = fraction(tf)[0] / factor( expand( fraction(tf)[1] ), s )
(-c1*r3*r4*s - r3 - r4)/(r2*(c1*c2*r3*r4*s**2 + s*(c2*r3 + c2*r4) + 1))
That's not in standard form. But at least it's right.
As I wrote earlier, you can easily work out the transfer function for the 2nd stage and then apply it to the above.
1st stage transfer function using ratios
It's more interesting to do this, though:
c1 = gamma*c2
r3 = rho*r4
zc1 = 1/s/c1
zc2 = 1/s/c2
-r4*(c2*gamma*r4*rho*s + rho + 1)/(r2*(c2**2*gamma*r4**2*rho*s**2 + s*(c2*r4*rho + c2*r4) + 1))
den = Poly( expand( fraction(tf)[1] ), s ).coeffs()
w0 = powdenest( sqrt( den[2]/den[0] ), force=True )
1/(c2*sqrt(gamma)*r4*sqrt(rho))
q = simplify( powdenest( sqrt( den[2]*den[0] )/den[1], force=True ) )
sqrt(gamma)*sqrt(rho)/(rho + 1)
Mostly the same approach. But now producing the same results I'd mentioned at the outset.
Notes
I chose to set the voltage at the (-) input to the 1st stage opamp to \$0\:\text{V}\$ for the analysis. I did not forget to deal with KCL for that node. But the node voltage doesn't show up as a variable, since it isn't variable. (Not enough to bother with, anyway.)
Added: I didn't comment about interpreting the transfer equation for the first 2nd order stage, as I assumed you know the details well enough (from what I saw in your writing.) You can see that the numerator indicates a low pass plus a bandpass. Sallen and Key do cover eighteen different types of passive structures; those they felt were important. But not this one. (They did say that others were possible, of course.) So I'm not sure you could call this a Sallen & Key.
Also, it's wonderful to see the different perspectives your question generated. So I'm up voting your question. You have a lot to work with. (Though so far as I can see no one took on the question of the overall equivalent 3rd order \$Q\$.)
Added again: Forgot to mention that the schematic you show doesn't have a resistor at the (+) opamp pin, to ground. It's usually better to include one that helps deal with bias currents.
A design approach
Suppose you already know \$\omega_{_0}\$ (aka \$\omega_{_p}\$) and \$Q\$. Then start by considering the relationship:
$$\tau=C_2\left(R_3+R_4\right)=\frac1{\omega_{_0}\,Q}$$
Suppose you wanted \$f_{_0}=6400\:\text{kHz}\$ and \$Q=2.5\$. Then \$\tau\approx 9.95\:\mu\text{s}\$. May as well call it \$\tau=10\:\mu\text{s}\$ for design purposes.
Since capacitors have fewer value selections available, you would continue from here by selecting a value for \$C_2\$, but knowing approximately what you feel comfortable with for \$R_3+R_4\$. If the sum of those resistors might be in the vicinity of \$10^5\:\Omega\$ then the capacitor will be in the vicinity of \$10^{-10}\:\text{F}\$ or \$100\:\text{pF}\$.
Making the capacitor a little larger will make the resistors a little smaller. You get the idea.
Let's say that I've got nice quality \$68\:\text{pF}\$ capacitors on hand. So now I can set \$C_2=68\:\text{pF}\$. And find that \$R_3+R_4\approx 146.3\:\text{k}\Omega\$.
We can also work out (I'll leave the details for you to explore as I don't want to take away from you the chance to discover why) that \$\gamma\approx 4\,Q^2\$. So we know that \$\gamma\approx 25\$. This means that \$C_1\approx 25\cdot C_2=1.7\:\text{nF}\$. We can choose a nearby value of \$C_1=1.8\:\text{nF}\$ and then re-compute \$\gamma=\frac{1.8\:\text{nF}}{68\:\text{pF}}\approx 26.47\$.
Now we can find the two possible values for \$\rho\$: \$\rho\approx 1.61678\$ or \$\rho\approx 0.6185\$. (Doesn't really matter which one you pick.) This means that we need these two resistor values: \$90.4\:\text{k}\Omega\$ and \$55.91\:\text{k}\Omega\$. The nearby values would be \$91\:\text{k}\Omega\$ and \$56\:\text{k}\Omega\$. From here, we find that \$R_3=56\:\text{k}\Omega\$ and \$R_4=91\:\text{k}\Omega\$. Now \$\rho\approx 0.6154\$.
Now we can recompute \$f_{_0}\approx 6373\:\text{Hz}\$ and \$Q=2.4985\$. Those are very close to the design values. (But you have to take that with a grain of salt, given resistor and capacitor tolerances!)
The above procedure has the advantage that it doesn't force you to select a specific \$\gamma\$ or \$\rho\$, in advance. It lets those flow out of natural decisions regarding available rationalized values for capacitors and resistors, instead, and proceeds to a design-end that achieves the frequency and Q.
Let's instead say that you know in advance that you want \$\rho=1\$. Then you would know that \$R_3=R_4=\frac{4\,Q}{2\,\omega_{_0}\,C_1}\$. (See if you can work out why.) If you selected \$C_2=62\:\text{pF}\$ then \$C_1=1550\:\text{pF}\$. That's not available, but \$C_1=1500\:\text{pF}\$ is. Now compute \$R_3=R_4\approx 82.9\:\text{k}\Omega\$. But that's also not available, so select \$R_3=R_4\approx 82\:\text{k}\Omega\$, instead. Now compute \$f_{_0}\approx 6364.5\:\text{Hz}\$.
That just happens to be about the value I get for your circuit! If I had to guess about it, I imagine that the design criteria might actually have been \$f_{_0}=6400\:\text{kHz}\$ and \$Q=2.5\$. Given \$C_2=62\:\text{pF}\$ and a requirement that \$R_3=R_4\$ as a starting point, it's difficult to imagine escaping the actual design you have. So that's my guess.
Added Note
This arrangement looks very similar to a multi-feedback low-pass amplifier. (See page 79 (schematic) and page 96 (design steps) at Basic Linear Design, Chapter 8.)
The difference is that the input resistor in the multi-feedback low-pass amplifier feeds to the middle of your T network instead of directly to the (-) input.
Still, you'll find there that the design process again starts by selecting a value for your \$C_2\$. They then develop a value for your \$C_1\$ next, in a fashion not unlike multiplying by \$4\,Q^2\$ (see the meaning they use for \$\alpha\$ to recognize this.) They then let the resistors fall out from those early steps. This is unlike what the designer of your schematic did in setting \$R_3=R_4\$ as an early step. But I think Analog's process could be adapted, similarly.
I'm curious if your schematic has an accepted name. The input resistor in the configuration shown on Analog Devices' document impacts the voltage gain. In your case, it doesn't, and instead represents the input impedance. This modification seems almost too obvious, in hind-sight.
(And it most certainly does not look like a twin-T notch. See page 105 from the PDF link above, to see why.)
