I'm working with an AL5810Q, which is a linear LED driver where the current can be set with only one external resistor following $$I_{LED}=\frac{750}{R_{SET}}.$$ With that, since I need a current of 10mA I calculated an external resistor of 75kΩ. (Vin = 12V)
I did a simple test following the schematics provided in the datasheet, which are the following enter image description here
So far, so good. 10mA Sharp.
However, the application I have in mind considers a very high line impedance (≈100Ω/mm) so I wanted to model that impedance by means of a resistor of 330Ω, which would leave the previous schemes like this:
by implementing these resistors the current is no longer constant and becomes a ratio to the voltage.
To be honest, I was not expecting this behavior, but it doesn't surprise me. The block diagram is as follows (with resistors)
can anyone shed some light on what might be happening and what I can do to fix this.
  • 4
    \$\begingroup\$ What's V_in and R? It can only be compliant up to a certain voltage. Edit the details into your question. \$\endgroup\$
    – Transistor
    May 17, 2021 at 13:21
The minimum voltage drop across the device is 2.5 V. Add in a couple of green LEDs and you've got a minimum voltage drop of 2.5 + 2 × 2.2 = 6.9 V.
If your supply is, say, 12 V then the maximum cable voltage drop is 12 - 6.9 = 5.1 V giving a maximum resistance of V/I = 5.1/10m = 510 Ω. At 100 Ω/mm that would give you a max of 5 mm of conductor before you're in trouble.
You can recalculate for your supply voltage.
  • \$\begingroup\$ makes sense to me. However, I have done two independent tests, one with a red led and the other with a white one (both using the same resistor I mentioned above 330 ohms.) which have a voltage drop of 1.8 and 3 respectively, so there should be enough space to not have this behavior? \$\endgroup\$ May 17, 2021 at 14:42
  • \$\begingroup\$ Also, what I see from playing with the source is the current makes a curve, peaking at the desired current (10mA) when Vin = 7 to 9 V. Before and after it decreases. \$\endgroup\$ May 17, 2021 at 14:51
  • \$\begingroup\$ You haven't supplied the detail requested under your question and the information in the comments above is a bit vague. Tabulate it properly in your question along with details of the series resistance. \$\endgroup\$
    – Transistor
    May 17, 2021 at 15:13
  • \$\begingroup\$ I did but in the question itself. Anyways. R= 330Ohms and Vin = 12V. Now I'm making some test with a white LED (OSRAM LW Q38E-Q1OO-3K6L-1) and with an R-value of 200Ohm. Vin<6.8V, I<10mA. when 6.8<Vin<8.9V, I=10mA and when Vin>8.9, I<10mA. \$\endgroup\$ May 17, 2021 at 15:40
Any constant current source must have a minimum voltage drop to regulate the feedback and internal drop. Adding excessive resistance will defeat this requirement.
