I'm making a battery voltage meter with a Wemos D1 Mini. The Analog input has a Vref of 3.2v. The battery that i will measure is a Lithio one of 72v, minimal 68V to max 84V, the Analog Input of the Wemos give to me (3.2v / 1024) of precision and i need more precision because with a resistor divisor i have a range from 0-90v but i will not use 0-60v, so my question is if with a OpAmp (i have a LM324) and some resistors i can map 60v-90v to 0v-30v and then use resistor divisor to down to 0-3.2v and get more precision with the ADC. The resolution that i want get is aprox 3mV-5mV
Update
I was used the document "Designing Gain and Offset in Thirty Seconds" with this values: Excel with values
And used proteus to simulate the circuit of positive m and negative b
Like you see Vref' not is same (even closed) to calc and Vout is outside 3.1v range of calc... what I'm doing wrong here?
The voltage conversion could be implemented like this:
To obtain:
Vref can be generated using precision adjustable reference (e. g. tl431) and R2 can be a trimpot. If you have specific requirements regarding the opamp power rails, reaching 0V could require some changes.
  • \$\begingroup\$ Thanks for the response... \$\endgroup\$ Commented May 17, 2021 at 22:14
  • \$\begingroup\$ the only problem is high current drawn from the battery. I have same problem and I do not to draw more than 70nA from the battery. Any idea? \$\endgroup\$ Commented May 18, 2021 at 0:45
  • \$\begingroup\$ @0___________ how much mA draw from battery?? \$\endgroup\$ Commented May 18, 2021 at 4:16
  • \$\begingroup\$ @vangelo Why 13.6v for Vref?? can be 12v?? \$\endgroup\$ Commented May 18, 2021 at 4:17
  • \$\begingroup\$ @LuisFelipeDominguezVega To change the original range to the (initially) desired one we have: (84 - 68) / 3.2 = 5. So the minimum voltage will be 68 / 5 = 13.6, which needs to be subtracted. The maximum current required from the battery is: 84/(47000+5222) = 1,609 mA. \$\endgroup\$
    – devnull
    Commented May 18, 2021 at 14:37
