recently ive been working on a sstc solid state tesla coil project.I am using IR2110 gate driver ic for driving my IRFP450 N-channel mosfets in half-bridge configuration.so the IR2110 ic have two inputs which is the high side input(hin) and the low side input (lin),for the high and low side inputs i cant directly connect my oscillator circuit two both pins which will short the mosfets,so for that ive designed a simple circuit consist of an hex inverter ic The 74HC14 hex inverter. The signal from the oscillator circuit and the antenna goes to the pin 1 of the ic (1A) and in pin 2 (1Y)i should get a low output that i can connect to low side of the mosfet driver and pin 2 (1Y) will be connected to pin 3 (2A) thus the pin 4 (2Y) should theoratically output a high signal that i can connect to the high side of the mosfet driver ic
Long story short can i get the desired high and low signal via this circuit?
And finnaly,im running the entire setup with a total of 25v for the half bridge,12v for the gate driver ic and 5v for the logic side
The frequancy is roughly around 450khz with 60% duty cycle
Edit:for some reason i cant post any comments,so im really sorry if not not replying im having some problems And i will do some research and try every circuits that you guys provide,im really sorry
